electrical gremlins in 1990 jimmy
Discussion in 'The Garage' started by dodgedude99, Jan 11, 2006.
  1. dodgedude99
    dodgedude99 1/2 ton status
    Jul 12, 2003
    784
    burbia of illinois
    ok my step sons POS Jimmy has some electrical issues.
    if he first starts the truck in the morning, the brake lights, turn signals, and back up lights all work. after it has run 5 minutes they stop working.
    it almost seems like once the truck warms up, the lights **** up with it.
    if he just applies the brakes, just the brake lights come on.
    if he puts the turn signal on and hit the brake, the tail lights and back up lights flash and alternate like a cop cars.
  2. Leper
    Leper 1/2 ton status
    Feb 18, 2005
    4,437
    Dallas Baby!!!!
    Be sure that you don't have a single element bulb in a dual element socket and check the grounds at the reat taillight housings. The grounds will cause that for sure.
  3. dodgedude99
    Jul 12, 2003
    784
    burbia of illinois
    even though it is fine for like 10 minutes then starts to do it?
  4. zeroz400
    zeroz400 1/2 ton status
    May 30, 2004
    410
    Libertyville, IL
    I had a problem with my truck where it would be fine till i hit the brake, then it started getting funky. Just had to fix the ground behind the driver side tailight.
