electrical gremlins
Discussion in '1969-1972 K5 Blazer | Truck | Suburban' started by Ressurection, Sep 10, 2001.
  1. Ressurection
    Ressurection 1/2 ton status
    May 9, 2000
    360
    Prairie du Sac, Wisconsin
    How do I go about tracing a short? I have no more signals and my front marker and signal lights light up when I press the brake pedal. HELP!!!
    "High compression engines take longer to start!"
  2. BluThndr71JMMY
    BluThndr71JMMY 1/2 ton status
    May 12, 2000
    152
    Tucson, AZ
    You need a multimeter and a schematic diagram. Chase down the lines one by one. Chevy's easy -- all bright colors and clearly marked in the wiring diagram. Check all your bulbs for continuity, check all your sockets for 12 volts good. Sometimes something simple like a turn signal switch shorting out or bad contacts to the brights hi/lo switch can cause a complex gripe like you describe. Look for broken, rat-chewed, or burned out lines.Disconnects, Misconnects? Keep after it. Good luck.
  3. chevyracing
    chevyracing 1/2 ton status
    Sep 8, 2001
    2,589
    Colorado
    Another way to isolate the problem is go to your fuse box and pull one fuse out at a time until the problem stops. That will give a little better idea on where to start maybe. With the problem you described there you may want to check the trailer plug if you have one, it may be a short across a couple of pinched wires. Mine did that same thing but my headlights would glow a little as well (kind of creapy looking). When I pulled my fuel tank and cleaned and relined it the trailer cord got into one of my hangers unbeknownst to me and shorted across my brake/turn signal and the tail light wire.
    john
    Like to go sloppin' 'round in da mud in a rapid fashion....=)
  4. LKJR
    LKJR 1/2 ton status
    Apr 18, 2000
    2,116
    Lubbock, Tx
    if you find a pest control system for these gremlins let me know I need about a gallon of it for my rig too
    Like em big and topless
    Excuse me...Would you mind removing your from import under my chevy?
  5. Ressurection
    May 9, 2000
    360
    Gremlins are gone!(?) Well, after removing the instrument cluster and fuse block, and not finding any freyed, burned, cut, etc. wires went and replaced both fuses in the engine bay (one by the battery and the other in the same area-drivers side), and voila! my horn even works (didn't before!). Do those fuses have a major role in the whole electrical system? I put in 3 amp short fuses and they burned out right away. I now have 20A regular length. Is this a bad thing? Thanks for your replies!
  6. LKJR
    LKJR 1/2 ton status
    Apr 18, 2000
    2,116
    Lubbock, Tx
    yea they are a major part, I believe they are supposed to be 4A if i remember right
    Excuse me...Would you mind removing your import from under my chevy?
  7. Triaged
    Triaged 1/2 ton status
    Feb 21, 2001
    3,808
    CA (LA/OC area)
    What do those fuses go to? I haven't found any in the engine compartment yet. Only fuseable links.
    '71 Blazer CST w/ a 400sbc, 4" lift, 36" Supper Swampers, and alot of rust
    <a target="_blank" href=http://community.webshots.com/user/triaged>See it Here </a>
  8. LKJR
    LKJR 1/2 ton status
    Apr 18, 2000
    2,116
    Lubbock, Tx
    off the top of my head I don't remember, I think one goes to the lights and other stuff, probably power to the dash I would assume. check down by where the voltage regulator is, in that area, some people have probably took them out over the years.
  9. Steve_Chin
    Steve_Chin 1/2 ton status
    Mar 6, 2001
    1,126
    Foster City, CA, USA
    I don't have any fuses in my engine compartment other than the ones in the box I installed. Like Triaged, I only have a couple of fusible links in my engine compartment. Maybe this is a difference in early vs. late Blazers/trucks?
  10. BluThndr71JMMY
    May 12, 2000
    152
    Tucson, AZ
    I've got those little 4 A fuses in the corners between the radiator support and fenders on a '67 KE/10 suburban and a '71 Jimmy -- both have Deluxe guages. The same fuses are not present on my '68 CS/10 pickup -- standard guages (w/idiot lights). I think they are related to your ammeter circuit and connect the alternator (neg) to that indicator, The other side comes from the Batt/Starter (pos) side and the two inputs activate the ammeter to indicate Charging (+) or Discharging (-) states. I found the line diagrammed in my _'67 Chevy Chassis Service Manual_ for 1/2. 3/4 and 1-ton trucks. I think it's the Black 18 guage on passenger side and Black/White 18 on the driver's side. This is on the schematic for series CE 10-20-30 (02) trucks in the early vintage (pre-Blazer).I know from experience that replacing those fuses brought my Ammeter back on line and cured some charging gripes. <P ID="edit"><FONT class="small">Edited by BluThndr71JMMY on 09/28/01 02:23 AM.</FONT></P>
  11. Triaged
    Feb 21, 2001
    3,808
    CA (LA/OC area)
    I found those little guys in there this weekend. I found 2, 1 on each side near the front just behind the rad support. Dang those are some small fuses. Now I am even more currious as to where they go. I guess I will have to look it up in the wiring diagram to know for sure.
