Electrical Gremlins
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by vdubbin86, May 28, 2002.
  1. vdubbin86
    vdubbin86 Registered Member
    May 25, 2002
    55
    Alberta, Canada
    After driving for about 20 mins my wipers make a swipe across my windsheild. And it happens about every 10 mins after that. Even though the switch is off.
    Any suggestions?
  2. chevyfumes
    chevyfumes Court jester
    Feb 24, 2000
    38,584
    266
    Watch for the muzzleflash!
    Try replacing the switch, atleast you have intermittent wipers, my choices are "way too fast and ridiculously too fast".../forums/images/icons/laugh.gif
  3. COLLISION
    COLLISION 1/2 ton status
    May 15, 2002
    175
    Kelowna,British Columbia
    are your wipers intermittent/delay???? or are they stock lo high and mist setting
  4. vdubbin86
    May 25, 2002
    55
    Alberta, Canada
    Yeah they are intermittent.
  5. vdubbin86
    May 25, 2002
    55
    Alberta, Canada
    Haha. I got pw, pl, A/T/C too. (When they decide to work) I'm stylin. lol
  6. jberg62
    jberg62 1/2 ton status
    May 7, 2001
    104
    Long Island,NY
    Try turning them on and then off again when that happens and they should remain off after that.
    I think the problem lies within the switch itself and the contacts probably needs to be cleaned or something.
    People usually say that the problem lies within the printed curcuit board for the wiper motor and that is under the hood.
    I can just never seem to find out exactly what is causing it.
    I just do what I said above and it seems to cancel it out.
    No, it's not a fix...just a bandaid.
  7. vdubbin86
    May 25, 2002
    55
    Alberta, Canada
    Ok, Thanks. I'll try that.
  8. Michael
    Michael 1/2 ton status
    1,576
    Sherman, Texas
    The wiper motor has a "park" switch that allows the wipers to stay on until they reach the park position. There is a cam that actuates this switch. When the wipers get to that position the switch opens. There may be something causing the switch to close, a bump, vibration etc., and causing a swipe. The park switch is under a plastic cover on earlier models....I'm not sure what you're dealing with since your profile doesn't say and your name seems to refer to an 86 VW(?).
  9. Michael
    1,576
    Sherman, Texas
    The wiper motor has a "park" switch that allows the wipers to stay on until they reach the park position. There is a cam that actuates this switch. When the wipers get to that position the switch opens. There may be something causing the switch to close, a bump, vibration etc., and causing a swipe. The park switch is under a plastic cover on earlier models....I'm not sure what you're dealing with since your profile doesn't say and your name seems to refer to an 86 VW(?). /forums/images/icons/wink.gif
  10. vdubbin86
    May 25, 2002
    55
    Alberta, Canada
    Yep, My name is for my old 86 VW. I just kept the name cause it was easy to remember and seems to always be available. I updated my profile with the truck info. It's an 81 Blazer. Thanks
