Electrical Gremlins
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Logan, Aug 2, 2000.
  1. Logan
    Logan Registered Member
    93
    Fournier, Ontario, Canada
    I'm about five minutes away from torching my truck for the insurance money, so somebody, please help!
    My trucks in an 84 Fullsize Jimmy, with a recently-replaced 350.
    The first problem I noticed is that my indicators no longer work. I swapped the flasher relays around, and the Hazard lights will work regardless of which flasher is in which slot. No turn signals either way.
    The second problem is that the the alternator keeps burying the voltmeter needle on the 18V side, every few seconds. This started 3 days after the above. The battery checks out at a little over 12 volts, and the acid level is fine. The stereo cuts out when this happens. This just started today. I haven't had it out for a long drive yet, so it may be the P.O.S. brake controller (See below) was shorting out and killing the battery.
    Third -- Power locks no longer work. Even with the truck off, they click or clunk every few seconds. The doors won't lock or unlock, even with the engine running. I've had to disconnect these under the dash.
    Fourth -- Moron, who owned the truck before me, decided he needed an electric brake controller for his trailer. I'm not even going to go into the wiring job he did, but needless to say it didn't seem to like being run at the 18 volts that the alternator was trying to feed it. I was able to scrape most of the melted plastic off of my left shin. To complement the wiring job, he installed the thing with stripped and bent flathead screws. After an hour of swearing in the most humid weather I've seen so far this year, I gave up and hacksawed it out.
    The truck has been running fine for the last month -- I replaced the original (dead) 305 with a junkyard 350 in early july.
    I've seen a few posts where people who've had engines replaced have problems like mine, and it ends up being a ground strap or something. I've managed to find one of these -- on the passenger side attached to the firewall. Are there more?
    Does anyone have a picture of what the fuse box layout is supposed to look like? I can't read a single word on the box....It's all a big white smear. I want to know which fuse controls what....Horn, headlights, dimmer, gauges etc.
    Any help is appreciated. Otherwise, keep a close eye out for my fire sale! ;)
    -Al.
  2. rocko
    rocko 1/2 ton status
    Jul 3, 2000
    3,380
    Ellsworth, Maine
    If I'm not mistaken, the Alternator Bracket also has a grounding strap that connects to the frame.. Have you checked that?
    It's better to have it than to not need it, then to need it and not have it. !!!
  3. Eagle86K5
    Eagle86K5 1/2 ton status
    Mar 5, 2000
    974
    Whitehouse, Ohio
    Your lucky day...see attachment
  4. beefcake83
    beefcake83 1/2 ton status
    Jun 24, 2000
    240
    Alaska
    My favorite is coming across wires that have been twisted together and wrapped loosly with electrical tape. Can you say, "ELECTRICAL TERMINALS!!!" Even found two wires connected with a band-aid! The rig I have now, the previous owner used the smallest SPEAKER wire out there from the battery to the stereo as the Batt + for the memory! Some folks should be banned from working on their own vehicles! Good luck! - Gary
    Gary Graham
    '83 GMC Jimmy 350 'Beefcake'
    Eielson AFB, Alaska
    Metallica & Mountain Dew
  5. Logan
    93
    Hey, thanks Eagle and Rocko -- I'll check out the ground strap tomorrow. Thanks for the fuse box pic!
    -Al.
  6. Michael
    Michael 1/2 ton status
    1,576
    Sherman, Texas
    My alternator bracket has a big ground going directly to the battery. If ya don't have that you'll have lots of problems. The engine/alternator should have the biggest ground, then frame and body. It's truly amazing how badly wiring gets screwed up!! Good luck!
    Michael [​IMG] http://jmartin.net/parker/goose.htm
