Electrical help please.....
Discussion in 'The Garage' started by stallion85, Apr 4, 2006.
  1. stallion85
    stallion85 1/2 ton status
    Jul 11, 2003
    3,659
    Cedar City, UT
    I am relocating my battery to behind the drivers seat and want to know if it would be ok to wire my winch to the starter instead of all the way back to the battery.
    In theory since the batt will be hooked up to the starter the voltage should just continue on right?
    Will this work? I don't want to run two hot leads all the way to the battery....
  2. AZ79K5Project
    AZ79K5Project 1/2 ton status
    Jan 15, 2006
    2,082
    Arizona
    A couple of things to consider
    Run length and voltage drop.
    The longer the run, the bigger the cable needs to be for the winch.
    I personally would not. I would run a very large gauge wire to a positve wire block and take the winch off from that and run the wire to the starter from there. I get nervous with two large wires running down by the exhaust.
    http://parts.factoryfive.com/newcatalog/plumbingelec/remoteterm.htm
    Or here is a link to a safe two positve wire alternative:
    http://www.americanautowire.com/products/Battery_Cable_Kit.cfm
  3. BizeeB65
    BizeeB65 1/2 ton status
    Oct 12, 2005
    859
    Louisville, KY
    Wouldn't reccommend it either. Esp if you are using a regular battery. What are your reasons behind relocating it?
  4. stallion85
    Jul 11, 2003
    3,659
    Cedar City, UT
    I narrowed my front end. I have a yellow top optima......
  5. BizeeB65
    Oct 12, 2005
    859
    Louisville, KY
    No way to mount it near the firewall? That would make your run a little shorter to the winch than behind the rear seat.
