Electrical issue-1st Gen, need help!
Discussion in 'The Garage' started by Ressurection, Jun 16, 2005.
  1. Ressurection
    Ressurection 1/2 ton status
    May 9, 2000
    360
    Prairie du Sac, Wisconsin
    :confused: Plugged the plug into the back of the dash tonight and had very dim dash lights and courtesy lights, but NOTHING when I turned the key on. ??? I've been running with the plug disconnected from the dash, and a jumper in the contacts that light the courtesy lights, which by the way, also allows the key to start the truck. Could this be simply a bad ammeter or voltage regulator? Or is it something more complex?
    HELP!!! :(
  2. Russell
    Russell LB7 Tahoe Status Premium Member GMOTM Winner
    Jun 23, 2000
    7,924
    334
    Fort McMurray, Alberta
    Sounds like a ground issue to me...
    Try checking your grounds to make sure everything is happy. I forgot to hook up the ground wire on my 74 when I first got it, all my gauges worked properly, but when I turned the headlights on, I'd get interior lights turning on, dash lights only kinda on, and a signal light on solid, inside and out, lol
  3. Ressurection
    May 9, 2000
    360
    Are you talking the main ground from the battery cable? Or where?
  4. Russell
    Jun 23, 2000
    7,924
    334
    Not 100% sure about the 1st gens, but my 74 had a ground wire that ran from the harness that went up to the gauge cluster down to the parking brake bracket. I knew about the wire, I just forgot to hook it up when I put the truck back together.
  5. 3 on the tree
    3 on the tree 1/2 ton status
    Oct 16, 2004
    3,970
    gunnison colorado
    Haven't looked under the dash but, up front there are 3 grounds that I know of on my 70. Neg batt cable to engine block, ext volt reg to core support, pass inner fender to frame. I'm sure there are more, but that's what I saw cleaning the engine compartment.
  6. Roz
    Roz 1/2 ton status
    Mar 27, 2005
    900
    San Diego
    i would say grounding also, check the contacts on ure wires, and there should be one to the dash.
