Electrical issue
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by bnc04, Sep 20, 2004.
  1. bnc04
    bnc04 Guest
    Hi, My 88 has developed an electrical issue. The battery and Alt have tested out fine. The volt meter while running is in the 9-10 volt range. ( it used to be 11 or 12) It drops to 8 when I use the power windows. It seems to fluctuate a little higher and lower while driving. Sometimes when I apply the brakes the radio will stop playing for 5 seconds ( cd or radio) both do it. The windows go up and down pretty slowly and the idle seems to surge ever so slightly now. Where should I begin to look? Checking the grounds I will do this afternoon. Anything else? Thanks in advance,
    Brett
  2. opfor2
    opfor2 1/2 ton status
    Oct 28, 2002
    375
    Ventura County, CA
    My 90 K-5 does something like that too, I have a new 200 amp Alt and when I run the AC and fan on high the volt meter drop's down to like 10 volts. You'ed think that with a 200 amp Alt that wouldn't happen.
    Dan..
  3. cybrfire
    Dec 15, 2002
    15,139
    565
    Iowa
    If the batt and alt are truly good then I would say start checking connections. You got something loose or corroded somewhere.
  4. zeroz400
    zeroz400 1/2 ton status
    May 30, 2004
    410
    Libertyville, IL
    When your truck is running it should be in the 12-15 volts range. I would check you ground wires, they may be corroded or dirty. A battery is approx 12.6volts so if ur battery isn't that when you go to start it i would say the battery is the culprit.
    Later
  5. BAJA_BLAZER
    BAJA_BLAZER 1/2 ton status Author
    May 17, 2001
    517
    San Diego, CA
    I'll second that! Check/replace the ground leads.
  6. uao85
    uao85 1/2 ton status
    Jan 2, 2004
    1,867
    Edge of insanity
    use a bigger gauge wire running from your alt to your battery to let the juice flow back to the battery better. Helped for me.
    Remington
  7. bigburban383
    bigburban383 1/2 ton status
    Dec 30, 2003
    1,242
    Michigan, Royal Oak
    The alternator test you did is obviously not right. A passing score would include 14-15 volts when the engine is running. Take it to a shop and they will put a load on the system to test the alternator and battery.
