electrical issue
Discussion in 'The Garage' started by cegusman, Aug 4, 2006.
  1. cegusman
    cegusman 3/4 ton status
    Apr 25, 2001
    6,793
    Houston/Katy, Tx
    Have a problem with my right turn signal in the grill. It works fine when the lights are off, but when the lights are on only the side marker and tail light blink. The one in the grill just stays solid. What could cause this? I plan on trying a spare headlight switch when I get home.
  2. TheSunDanceKid
    TheSunDanceKid Registered Member
    Jul 22, 2006
    60
    arizona, gilbert
    well have you messed with any wiring at all or done some good ramping that could of knocked something loose if not then its probably the switch or relay
    sounds like you tryed to wire something because usally when you have the keys out of the ign and turn the blinkers on nothing happends intill you turn it to the run position
  3. cegusman
    Apr 25, 2001
    6,793
    Houston/Katy, Tx
    wireharness is a brand new custon one. Yes with the keys off I get nothing like it should, I was saying when I turned my lights on is when the turn signal would quit working. Blinker relay is brand new too, it works fine, just not went the lights are on.
  4. hack500
    hack500 1/2 ton status
    Sep 16, 2005
    523
    Templeton, Ma
    are all the grounds, good?
  5. goldwing2000
    goldwing2000 Guest
    Yep. Bad socket ground, I'd say. With the lights off, it grounds through the other filament but when you send power to both, it just stays lit.
  6. cegusman
    Apr 25, 2001
    6,793
    Houston/Katy, Tx
    Grounds should be good but I will check them.
  7. goldwing2000
    goldwing2000 Guest
    Could be a bad socket, too. There's no other reason for one light to work wrong while the rest are working right.
  8. cegusman
    Apr 25, 2001
    6,793
    Houston/Katy, Tx
    Its a brand new socket too, but I will check it too.
  9. goldwing2000
    goldwing2000 Guest
    Might have some crossed wires in that brand new "custon" harness.
