Electrical Issues
Discussion in 'The Garage' started by 82_k5, Aug 9, 2006.
  1. 82_k5
    82_k5 Registered Member
    Oct 3, 2003
    94
    I know this isn't a Blazer but I'm pretty sure the wiring is exactly the same. I have an 81 Camaro and when I was cranking it to start this morning it just quit. All the lights and guages don't light up and the starter doesn't turn. I think I burned up a wire or a fuse somewhere. If anyone knows anything about what could cause the problem, it would be greatly appreciated. Thanks
  2. 1985_K5_Silverado
    1985_K5_Silverado 1/2 ton status
    Dec 21, 2005
    984
    Corn Country
    Fusible link, perhaps?
  3. dyeager535
    26,980
    Only one wire "tells" the starter to turn over with the key. (often purple) If it won't turn over, either the starter solenoid isn't getting the signal to crank, the starter itself is bad, or the battery/cable is bad or not connected well.
    Give all the wiring a good visual first, you may see something cooked or pinched, bare, etc.
    If you lost lights and all, I'd make sure your battery cables are ok first, then check for power at the fuse panel. If no power there, check continuity on the red wires from the starter to the fuse panel. Should be fusible links, if they blow, no power to any of the accessories. Since you don't have crank OR accessories, I'd bet your fuse panel doesn't have voltage.
  4. AKbigsub
    AKbigsub 1/2 ton status Premium Member
    Sep 9, 2005
    1,549
    17
    Anchorage, AK
    Start simple and ensure that the battery terminals are not coroded and are making a good connection.
