Electrical Problem HELP PLEASE
Discussion in 'The Garage' started by blazer_boy03, Mar 22, 2004.
  1. blazer_boy03
    blazer_boy03 Registered Member
    Nov 2, 2003
    17
    Bellefonte Pa
    85 Gmc Jimmy Dual Head light set-up. When I turn the lights on all four light up, when i hit the high beam selector they all shut off. Selector swith is good i know that for a fact. Are the top lights a dual filiment light? they are 3 prong while the bottom ones are two prong. Any help would be great I am going nuts over this.
  2. dave_90_blazer
    dave_90_blazer 1/2 ton status
    Jan 1, 2004
    688
    Melvindale, Michigan
    three prong bulbs are dual filament
  3. SS66
    SS66 1/2 ton status
    Feb 13, 2003
    538
    WI, USA
    I got a nasty problem in a car. Every time the vehicle is turned on or a blinker is used.. smoke comes out of the steering column. /forums/images/graemlins/eek.gif
  4. shane74
    shane74 1/2 ton status
    Feb 12, 2002
    4,100
    Vancouver, WA
    I had that exact same problem in our Buick. Is it a tilt column? I had to replace the turn signal switch. The wires had rubbed bare in a spot and were shorting out on the column itself. Dont' worry..eventually it'll quit smoking and just go out completely on you. /forums/images/graemlins/histerical.gif
  5. SS66
    SS66 1/2 ton status
    Feb 13, 2003
    538
    WI, USA
    Yes it is /forums/images/graemlins/thumb.gif
