Electrical problem...no radio, running lights, interior lights...
Discussion in 'The Garage' started by Lotsa_Faith, Oct 5, 2003.
  1. Lotsa_Faith
    Lotsa_Faith 1/2 ton status
    Jul 10, 2001
    474
    Mckinney, Texas
    Happened a couple weeks ago, just got around to trying to fix it. Goin down the road, all the sudden radio cuts off, interior lights cut off. No running lights, fog lights, but brakelights, blinkers, and headlights still work. I've checked all the fuses in the fusebox, all good. What could be the problem? Its also a M1009 converted to 12 volt, so that doesnt help alot either...
  2. GMCLegacy
    GMCLegacy 1/2 ton status
    Jan 24, 2002
    620
    Grand Haven, MI
    it sounds like a fuse problem since i beleive all those are on the same curcuit. if it isnt the fuse i would look at your grounds in the cab. good luck
  3. bigblock44k5
    bigblock44k5 1/2 ton status
    Jun 8, 2003
    396
    Hurlburt Field, FL
    Check all the wires going to the starter, one of them might have burned off.
