electrical problem
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by 4x4blazer, Aug 20, 2000.
  1. 4x4blazer
    4x4blazer 1/2 ton status
    Jun 14, 2000
    278
    Louisiana
    Ok, now that I have my new engine in, my guage lights, dome lights, and headlights wont work. Also, my temp guage wont work and it is a brand new sending unit. All of this stuff worked before and I checked all the fuses already. Any ideas on any of this stuff? Thanks for any help.
  2. Grim-Reaper
    7,385
    Atlanta
    My guess is you forgot the ground strap off the passenger side head to the fire wall, you know the one that you missed when you were pulling the engine :) You can't see that booger once the engine is in. 3/8x1/2 inch bolt (9/16 wrench size) in any of the unused holes on the back of the head. If you broke the strap when you pulled the engine Pep Boys and Autozone usualy have new ones in stock in the Help section.
    Diging it in the dirt with my K5's
    Grim-Reaper
    http://grimsk5s.coloradok5.com/
  3. 4x4blazer
    Jun 14, 2000
    278
    Louisiana
    nope cant be the ground strap, i have a new one on there. anything else it could be?
  4. sosamantx
    sosamantx 1/2 ton status
    Aug 14, 2000
    393
    somewhere in Texas
    Maybe the headlight switch just bit the dust? Do you have voltage going to the fuse, to the switch? What about to the headlights? I know it seems kinda odd, but maybe it just died? Just my opinion. - Steve
    Steve Sosa a.k.a. "sosaman"
    http://sosaman.home.texas.net/carpics.html
  5. Grim-Reaper
    7,385
    Atlanta
    Well it sounds like you lost the main power and usualy thats the ground strap. The main power lead connects at the starter. Maybe you missed it when you bolted things back in. Depending on the year there are 2-3 leads that need to be on the same bolt as the battery lead. You obviously got the one for the start circuit since it will crank but maybe you missed the main power lead for the cab. Also check the big plug for the main power on the firewall under the brake booster and trace the wires back from that.
    Grim-Reaper
  6. Dave A
    Dave A Registered Member
    Jul 18, 2000
    33
    St. Louis, Missouri
    I know you replaced the ground strap but man, this feels like a ground problem! Make sure that where the strap is attached to the firewall is clean, use a wire brush or similar on it. I had a headlight that quit all of a sudden once, I looked at the ground and it looked clean but I came back to it after everything else checked out. Wire brushed it and that did the trick.
  7. 4x4blazer
    Jun 14, 2000
    278
    Louisiana
    Thanks for all the input guys. I just got home from work so I will go out and check all of this stuff in a few. I will reply again when I get it fixed and let yall know what it was.
