Electrical Problems 1990 K5
Discussion in 'The Garage' started by Hardcore, May 22, 2004.
  1. Hardcore
    Hardcore 1/2 ton status
    Apr 25, 2003
    458
    New Orleans, LA
    Having a weird electrical problem some of you guys may know how to fix.
    If I plug something into my cigarette lighter sometimes it will short out the radio for just a second. THe radio goes off but the interior light come on /forums/images/graemlins/eek.gif The radio loses its presets and everything
    Then sometimes when I open the door and the lights come on the radio goes off /forums/images/graemlins/dunno.gif
    The truck has a Viper alarm the previous owner had installed. I think it plays a part in it because usually a alarm is tripped when the door opens because the interior lights switch on and the alarm uses that as a signal. What I don't get is why it is cutting off my radio? Any ideas what this could be? In idea how the radio gets its power is affected by the interior lights????
  2. wayne
    wayne 3/4 ton status
    Feb 1, 2001
    6,178
    Carlisle, Pa
    The radio should have power to it all the time to keep the presets. Is the alarm tied into that for power? It sounds to me that the alarm is causing the problems. On my 90 if I short out anything at the cig lighter it blows the fuse and nothing else. Only time it has happened is plugging the cell phone in to charge. /forums/images/graemlins/dunno.gif
  3. Hardcore
    Apr 25, 2003
    458
    New Orleans, LA
    Yeah I started thinking they may have tapped into that wire for a constat power source, what I still don't get is why the radio goes off but it doesn't blow a fuse. I would think the radio would stay on or it would draw so much power the fuse would blow /forums/images/graemlins/confused.gif I'm really confused about the interior light thing also /forums/images/graemlins/confused.gif
    Anyone else ever have a similar problem?
  4. Hardcore
    Apr 25, 2003
    458
    New Orleans, LA
    Also does anyone know if the lights under the dash and the lights overhead are on the same circuit? My lights under the dash only come on, not the ones on the roof /forums/images/graemlins/dunno.gif
  5. daleearnhardt01
    daleearnhardt01 1/2 ton status
    Aug 29, 2002
    3,223
    Richmond, VA
    They are on a different circuit. I know I blew fuses for the overhead lights when my door jamb switch started shorting out...
  6. darkshadow
    darkshadow 1 ton status
    Dec 6, 2003
    12,250
    C-eh-N-eh-D-eh
    you have a bad short in your cigg lighter, if you pull the little door down and smack it you will see it spark, try to fix it or slap an after markit one in there. mine would do it when ever i hit a big bump in the road.
    The radio and ciglighter and something elce are all on the same fuse. have fun /forums/images/graemlins/waytogo.gif
  7. 83ZZ502_Jimmy
    83ZZ502_Jimmy 1/2 ton status
    Feb 7, 2001
    3,103
    Richmond, VA
    Agreed
  8. Hardcore
    Apr 25, 2003
    458
    New Orleans, LA
    Any idea why the radio goes off when the door is opened though?
  9. Derf00
    Derf00 1/2 ton status
    Jul 25, 2000
    1,683
    Abilene, TX
    The cig lighter circuit also has the horn and the upper interior lights on it. I had a bad cig lighter and could be driving down the street and hit a bump and it would blow the fuse, it took a while to figure it out.
    I think the radio looses power because of the alarm system or bad joints or ground in the alarm system.
  10. Hardcore
    Apr 25, 2003
    458
    New Orleans, LA
    Thanks guys, I'll play with it this weekend and see what I find /forums/images/graemlins/thinking.gif
