electrical problems...need help
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by shupach, May 26, 2003.
  1. shupach
    shupach 1/2 ton status
    Dec 28, 2000
    648
    Dallas, TX
    well for the past month i've been trying on and off to get my blazer started, but this seeems like a lost cause of the blazer gods just hate me, one of the two. Right now i think i have a short but i cant for the life of me find it, i hooked up everything the way it is supposed to be but wat is really scaring me is the tranny cooler lines(you know the ones that go to radiator) they get extremely hot, infact i've even had them smoking!!!! and this is from the electricity it self!!! i've looked all around the lines and cant seem to find any wires touching or anything. can someone please help me out i've spent alot of time building this engine and now it wont even start!!
    thanks,
    phill
  2. chillywilly
    chillywilly Registered Member
    May 26, 2002
    70
    northern maine
    Holy Smokes!!!! Hot tranny lines? Check your big /main ground cable to engine.Sounds like its tryin to ground through cooler lines.
  3. shupach
    Dec 28, 2000
    648
    Dallas, TX
    ya i've actually hooked up a ground cable from the alternator to the frame and well that thing melted....
    phill
  4. BrianDamage
    BrianDamage 1/2 ton status
    May 14, 2001
    753
    Alabama
    phill
    shouldn't hook it to your alternator...I hope you are meaning to say you hooked it to your alternator mounting bracket
    sounds like a dead short somewhere. I had an El Camino do something similar...I was selling it and dude took it for a test drive, the battery cable going to the starter got against the exhaust and melted a spot through the insulation causing it to short out and melted both batttery cables.
  5. shupach
    Dec 28, 2000
    648
    Dallas, TX
    ya i had it on the alternator bracket, well i replaced the ground wire from the battery to the frame since it was gone, however i have a short now, and i cannot for the life of me find it.
    phill
  6. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    Do you have the main ground wire from the battery connected to the frame or to the engine? It should be attached to the engine block or the alternator bracket. The highest current draw is from the starter, so you want to make the circuit for it as short as possible.
  7. deek
    deek 1/2 ton status
    May 6, 2003
    142
    Great Bend, KS
    I agree with HARRYh3, but if you have any doubt take a test light from your tranny to your frame, if it lights up when somebody turns the motor over you have a bad ground off the engine. the battery cable from the alt. mount will create a path great enough for the power to pass. right now it's just trying to find another way back to ground
