Electrical problems
Discussion in 'The Garage' started by 6.2 man, Jun 25, 2006.
  1. 6.2 man
    6.2 man 1/2 ton status Premium Member
    636
    Curtis , WA
    I am wooried about my charging system . I have never had a dead battery but when I turn anything on my volt gauge reads like 13 volts . This is at any speed . I checked the alternator and show 14.5 at the post on the back . I show 14.5 at the batteries . I show 14.5 at the firewall . The other day i was idling thru a parking lot with the air on and my glow plugs kick in . So the system was detecting low voltage because my gauge read below 13 volts . Please help !!!!!!!!!!!!!!!!:confused:
  2. readymix
    readymix 3/4 ton status
    May 30, 2004
    6,706
    26
    Murrieta, California
    I wouldn't trust the factory gauge for anything other than to let you know that there is more than 0 volts there.
  3. JEBSR
    JEBSR 1/2 ton status
    Dec 23, 2004
    1,541
    Clarksville, TN
    Absolutely. I have seen more bad gauges cost people tons of money trying to fix a problem that doesn't even exist that it isn't even funny anymore. If you are worried, pull your cluster and check voltage at the gauge. Bet you'll find it's 1.5-3 volts off. I know mine is.
