electrical Q's
Discussion in 'The Garage' started by rwright07, Aug 14, 2005.
  1. rwright07
    rwright07 1/2 ton status
    Jul 30, 2005
    536
    corporate hobo
    i bought a 76 k5 earlier this month and im tryin to put in some electrical stuff.
    a cb, aftermarket horn stereo ect n im wonderin how i should run the wiring through the firewall
    any advice would b awesome
  2. diesel4me
    Jul 24, 2003
    17,568
    943
    Massachussetts
    look for plugged holes..
    Most all GM trucks have a few extra holes punched in the firewall,and have rubber plugs in them--you poke a phillips screwdiver thru the plug,it then becomes a grommet!--or you can yank it out and run ALL the wires thru.them put something like a slit hose to prevent them from chafing on the sharp metal and shorting out..the plugs resemble a male sex organ,they are installed from the inside of the cab,only a small "nipple" sticks out under the hood side...I used the ones closest to the gas pedal and fuse box most often.. :crazy:
  3. Roz
    Roz 1/2 ton status
    Mar 27, 2005
    900
    San Diego
    most of that stuff would be better to run off ure fuse box. it has extra spot for acc. so nice and fuse for ya.
