electrical question, need help please
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by chevyracing, Jun 21, 2002.
  1. chevyracing
    chevyracing 1/2 ton status
    Sep 8, 2001
    2,589
    Colorado
    I turn the headlights on and all of the gauges go to zero. Why? Oh, it is an 85 Blazer.
    John
  2. pr1aw
    pr1aw 1/2 ton status
    Sep 17, 2000
    144
    San Diego CA
    Sounds like a short in the switch, replace.
  3. Twiz
    Twiz 1/2 ton status
    Mar 8, 2001
    3,729
    Clearfield Ut.
    Possibly bad ground??
    Your going to get alot of guesses with a question like that, we need some mo' details please...
  4. reddog64
    reddog64 1/2 ton status
    Nov 9, 2000
    3,325
    Federal Way, Washington
    grounding problem... add a ground from your battery's negative post to the chassis... ie a body panel... or the front radiator support
  5. chevyracing
    Sep 8, 2001
    2,589
    Colorado
    I'll give it a shot. I had the dash out and put it back in when I noticed the problem. It is plug in and not too much to screw up so I don't know what happened. I just put this new engine in and have not hooked up a chasis ground yet.
    John
  6. JORGE
    JORGE 1/2 ton status
    Jan 10, 2001
    213
    VITORIA-GAZTEIZ(ALAVA)BASQUE COUNTRY,SPAIN
    With a hooked wire connected to the batt. negative,you can touch the gauges negative connection.If the pointer goes to her correct position,you knows wath is the trouble.A bad ground connection.
  7. chevyracing
    Sep 8, 2001
    2,589
    Colorado
    Figured it out. I am a retard. The connection for the dash was loose. I thought I plugged it in till it clicked. I hated to tear it back apart, but nothing was working. Thanks all for the advice.
    John
