Electrical Question
Discussion in 'The Garage' started by THISISWEIRD, Apr 14, 2007.
  1. THISISWEIRD
    THISISWEIRD 1/2 ton status
    Mar 10, 2007
    165
    WV
    I want to put a fuse block or something similiar with circuit breakers. Does anyone have a wiring diagram for that?
    I assume that it's just power from the battery to the fuse block. Then from the fuse block to whatever I want to power. Then ground that 'whatever' device on the other side. Is that correct? Or do I need to ground the fuse block too?
    How would I make the same thing but only where it turns when the switch is turned?
