Electrical question
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Dunc03, Oct 24, 2002.
  1. Dunc03
    Dunc03 1/2 ton status
    May 20, 2001
    157
    Tyler,Texas
    I have wires that run into my carb that also connect to an electrical post on top of the water jacket. I am re-wiring the thing with a PAINLESS SYTEM and this wire is not included, can I just hook it to another power source that is a keyed on source, or does this wire originate from the instrument panel or something. I have a 86 so its not computer controlled per say. I think the electronics going into the carb is called the Carburator Air fuel solenoid. Thank for the help guys, this thing is my last hurdle to having the wiring finished.
  2. 95 Silverado
    95 Silverado 1/2 ton status
    Nov 9, 2001
    467
    Central PA
    I believe that would be the mixture solenoid on your carburetor and it is computer controlled.
  3. dyeager535
    26,979
    I think he actually has the "cold only" mixture control solenoid, which is solely temp controlled, hence the "sensor" on the water neck. (if I interpret "water jacket" right)
    Computer controlled would have a bundle of wires running into the passenger side of the cab, not including the standalone truck ESC system used in some cases.
    CCC carbs use TPS and a mixture control solenoid...not one or the other.
