Electrical/steering column question...
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by 83k5inthefort, Jul 10, 2004.
  1. 83k5inthefort
    83k5inthefort Registered Member
    Jul 5, 2004
    20
    Seattle
    Hello again, everybody!
    Hopefully someone will read this who is experienced with 2nd Gen GM steering columns. About a month ago, the self-cancel on my left turn signal stopped working. Any suggestions on places to start looking, or common causes?
    Thanks again! /forums/images/graemlins/1zhelp.gif
  2. justhorsinaround
    justhorsinaround 3/4 ton status
    Sep 16, 2003
    6,798
    Northerish Phoenix, Az
    Take the steerin wheel off and then take a look at your turn signal mechanism and see if there's somethin loose or more probably broken. Prolly one of the little ears is no longer attached. /forums/images/graemlins/thumb.gif
  3. or2play
    or2play 1/2 ton status
    Feb 22, 2002
    657
    Yuma, Arizona
    I just replaced my entire switch. It was about 50 bucks from the dealer. You can also pick up a repair kit from the part stores. It has the two springs and the plastic cam. Also can get the horn/cancel cam in the part stores. None of it is too hard to replace. I'd recommend getting the lock plate puller. It will make life alot easier. Picked mine up at Sears.
  4. dyeager535
    26,975
    I've seen millions (ok maybe 10-20 lol) of those turn signal switches with a broken spring in them. If anything breaks on one of these switches related to the canceling cam, I'd suspect those springs first off. Pretty easy to check IIRC, as long as you have a steering wheel puller and the lock plate compressor, which you'll need anyways.
