electrical thing, plz help?
Discussion in 'The Garage' started by cannibal, Dec 17, 2003.
  1. cannibal
    cannibal Registered Member
    Mar 13, 2003
    56
    Amman, Jordan
    hi all,
    i posted a while ago about my rear brake lights that wont work, anyway, i bought all new fuses and the device that is attached to the brake pedal, i know that my bulbs are ok, but nothing happened, and so, the signal lights wont go either, they worked well but after a few min. they turned off, what the hell is goin on????
  2. Muddytazz
    Muddytazz 1 ton status
    Jun 30, 2002
    20,073
    Salem, Or.
    Check all the grounds?
  3. 83ZZ502_Jimmy
    83ZZ502_Jimmy 1/2 ton status
    Feb 7, 2001
    3,103
    Richmond, VA
    Check grounds. Make sure, at the battery, that you are grounded to the block with the large cable. Then there should be a small cable to the body off of the battery. Then make sure the block is grounded to the frame with a ground strap.
    After that, start checking the taillight grounds themselves.
    John
  4. cannibal
    Mar 13, 2003
    56
    Amman, Jordan
    ok, i'll do that, thanx, hope it will work
  5. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
    new flasher ?
