electrical trouble need help ASAP
Discussion in 'The Garage' started by chvymudin3388, Mar 21, 2007.
  1. chvymudin3388
    chvymudin3388 1/2 ton status
    Mar 3, 2005
    374
    orange grove ,tx
    headlights will not come one dash lights wont come on radio wont turn on and radio wont turn on. BUT windows work engine cranks not sure if fuel pump is turning on and i just put in a nother motor. there is a wire that is coming off of the hot lead that i dont remember where it went its an 87 tbi 350 blazer PLZ HELP ME
  2. chvymudin3388
    Mar 3, 2005
    374
    orange grove ,tx
    or if i coould maybe get a picture of where the wire im talking bout goes i kno it goes some where near the altenator
  3. JEBSR
    JEBSR 1/2 ton status
    Dec 23, 2004
    1,541
    Clarksville, TN
    So it was fine before the engine swap but doesn't work now? If so post that pic, check the wires going to the starter. Sounds like you may have left one off.
  4. chvymudin3388
    Mar 3, 2005
    374
    orange grove ,tx
    i never unhooked the starter it cranks fine and all but things dont work like the a/c and teh headlights or dash lights and thinga like that
  5. chvymudin3388
    Mar 3, 2005
    374
    orange grove ,tx
    so no one knows??? its an easy question guys i mean i know it would be alot easier if i could post a pic of the wire but i cant right now. its the skinny wire running of the original positive battery cable where does it go?
  6. Chrisblazzer89
    Chrisblazzer89 1/2 ton status
    Oct 12, 2006
    1,966
    Massachusetts 02301
    I will go take a pic of where it goes in the morning
  7. JEBSR
    Dec 23, 2004
    1,541
    Clarksville, TN
    The main wire on the possitive terminal goes to the starter and the small wire should go to the main post of the alternator.
  8. Thunder
    Thunder 3/4 ton status
    Jul 20, 2000
    8,946
    Northeast Nevada
    X2
    That small wire on the pos battery cable must be connected to the big threaded post on the alternator. There should also be ay least 1 other wire connected at that Alt terminal that feeds ign switch and powers the accesories and things that aren't working.
  9. chvymudin3388
    Mar 3, 2005
    374
    orange grove ,tx
    so it does go there... i wasnt sure... so if i hook it up i should gain power back to all that stuff???
  10. JEBSR
    Dec 23, 2004
    1,541
    Clarksville, TN
    yep, as long as both wires are hooked up.
