Electrical???
Discussion in 'The Garage' started by ysavila, Oct 1, 2005.
  1. ysavila
    ysavila Newbie
    Oct 1, 2005
    TEXAS
    ...Sorry the first post didn't all go thru........on my 1997 Suburban as soon I turn on headlight switch the #9 fuse blows which operates the tail light and instrument panel. I disconnected the tail light assembly's right and left and also instrument panel and replaced the headlight switch and the fuse still blows. any advise is greatly appreciated..Steven
  2. jhellwig
    jhellwig 1/2 ton status
    May 7, 2005
    420
    Bonaparte, Ia
    And..........??????????????? :confused: :confused:
  3. 4xcrazy
    4xcrazy 3/4 ton status
    Oct 31, 2003
    9,471
    5
    Olympia/Lacey, Washington
    headlight, on my '89 Burb
  4. mikey_d05
    mikey_d05 1 ton status GMOTM Winner
    Nov 23, 2004
    10,453
    Minnesota
    blinker fluid in my '93 blazer
  5. FreedomIsntFree
    FreedomIsntFree 1/2 ton status
    Aug 23, 2005
    124
    DFW, TX
    There is no such thing as blinker fluid on your '93 blazer. They came with an electical motor on the blinker with optional cam bearing and dual-slotted signal rotor! :D
  6. mikey_d05
    Nov 23, 2004
    10,453
    Minnesota
    However, the cam bearing a signal rotor need to be lubricated, some people use ATF as a cheap alternative, but the right way to do it is with a good quality DOT 7 or 8 blinker fluid. Whatever, I still need muffler bearings anyways.
  7. FreedomIsntFree
    Aug 23, 2005
    124
    DFW, TX
    Man those muffler bearings KILLED me. And since I've got a V8 I had to buy 16 of them. Gotta save up for the next set!
  8. Big89Burban
    Big89Burban 1/2 ton status
    Jul 19, 2005
    143
    Magnolia, Tx
    electricity
    noun {U}
    a form of energy, produced in various ways, which provides power to devices that create light, heat, etc: :rolleyes:
    Edit: Should I post the def. of @$$hat too? :haha:
    WELCOME TO CK5!!!! :p:
  9. FreedomIsntFree
    Aug 23, 2005
    124
    DFW, TX
    Well played! :waytogo:
    Where is Magnolia, TX by the way? Close to DFW?
  10. mikey_d05
    Nov 23, 2004
    10,453
    Minnesota
    You forgot momentum and rotation, most important in the functioning of starter motors and vibrators.
  11. Big89Burban
    Jul 19, 2005
    143
    Magnolia, Tx
    No. I'm about 40 miles nw of houston. Close to conroe
    edit:
    I believe the word your looking for in that one is Electro-mechanical. (i.e. something that turns electrical energy into and mechanical force) Just like a solenoid, but i beleive a starter motor could actually be in that same catagory. :deal:
    :haha:
  12. FreedomIsntFree
    Aug 23, 2005
    124
    DFW, TX
    Oh ok. I just moved here so I have no idea where anything is. Other than Austin and Houston and the major cities.
  13. Cmoe
    Cmoe 1/2 ton status
    Feb 19, 2000
    2,884
    Mesa,AZ
    You forgot to use it in a sentance!
  14. Big89Burban
    Jul 19, 2005
    143
    Magnolia, Tx
    :doah:
    My bro. lives in dallas. Works at mercedes up there.
  15. VikingWarlord
    VikingWarlord 1/2 ton status
    Sep 25, 2005
    293
    Flagstaff,AZ
    I was meaning to ask, if you substituted halogen fluid instead of Dot 7 or 8 blinker fluid, would the signal lights be brighter? Or just burn out faster? :wink1:
  16. Geargrinder
    Geargrinder 1/2 ton status
    Jan 21, 2005
    258
    Medford Oregon
    Any one know where a good place is to get the air in my tires rotated :confused: I tried LesShwabs but they said they don't have the equpment to do it any more :whistle: :whistle: :dunno: :screwy:
  17. chevydan3
    chevydan3 1/2 ton status
    Nov 27, 2004
    409
    Reno, Nevada
    You can change to halogen fluid but it is not much of an improvement if you ask me, and not worth the effort, because you actually need to buy a left handed screwdriver for the right side lense, and a right handed screwdriver for the left side lense. Without those tools, which are expensive, there is no hope of getting to the blinker fluid at all. Hope this helps. :D
    ALSO, TO EVERYBODY, IT IS THAT TIME OF YEAR TO DO YOUR ANNUAL SPARK PLUG ROTATION, DON'T FORGET, YOU WILL REGRET IT.
  18. FreedomIsntFree
    Aug 23, 2005
    124
    DFW, TX
    Wal-mart will not rotate the air but they WILL replace your old air with fresh "synthetic" air for .99 a pound!
  19. mikey_d05
    Nov 23, 2004
    10,453
    Minnesota
    That sucks for my DD since I run 35 pounds a tire. Guess it's just another reason to air down my trail rig though.
  20. FreedomIsntFree
    Aug 23, 2005
    124
    DFW, TX
    What's really sad is that I'm sure mechanics have used lines EXACTLY like these on unsuspecting women to get more money out of them!
