electrical
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by HEFTY, Dec 30, 2001.
  1. HEFTY
    HEFTY Registered Member
    Dec 18, 2001
    12
    connecticut
    I started having problems with my radio (aftermarket AIWA) it keeps blowing fuses. When the fuses blow they light up the interior of my truck at night, alot of juice. Fuse box says 10 amp its always had a 20 amp in it since i got truck, (after market radio draws more juice?) if i put a 20 amp in it can sometimes last up to a day or just blow right away.
    now my windshield wipers turn themselves on and off.
    i don't know if these are related or not, could the wipers just be a switch problem.
    sorry so long, thanks in advance
  2. tRustyK5
    Jul 23, 2000
    36,170
    1,376
    E-town baby!
    I don't know about your radio but my wipers are 'posessed' too...
    Rene
    <a target="_blank" href=http://coloradok5.com/gallery/project_T2> tRusty pics...</a>
  3. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    Most car radios don't draw more than 5 amps or so. Sounds like there's a bare wire in your radio wiring that is occasionally shorting against a piece of grounded steel somewhere. You'll have to get under there and examine the wiring closely.
    And get rid of that 20 amp fuse! If the circuit is labeled for a 10 amp fuse, then the wiring for that circuit is using very thin wire, and is only rated for a 10 amp load. A full short draws enough current to blow the fuse quickly. But if something in the radio were to go bad and cause a, let's say 18 amp constant load, then the wiring would overheat and set your truck on fire. NOT a pretty scene. Fuses are there to prevent this from happening. Using a fuse that's rated at a higher current reduces your protection.
  4. HEFTY
    Dec 18, 2001
    12
    connecticut
    thanks, the more i get into my electrical the more i think i have a fire waiting to happen. someone put in electric windows and rear gate window and didn't do the safest install. the electrical seems pretty rigged up. i'm almost glad for the problems ive had with my truck ive discovered some very unsafe things which i have fixed and continue to do.
    i just hope i don't have to rewire the whole truck.
    from what i have found all the wires are not bare, we also bypassed those wires and still blew the fuse, maybe a radio problem or in the fuse box?
  5. Nonesuch
    Nonesuch 1/2 ton status
    Jul 16, 2001
    1,467
    Austin(Leander), TX
    test the grounds for power with a voltmeter. if you find power on a ground you have a short. I had radio, interior lights and horn probs and you will never guess what was causing it..............a bad cigareete lighter! double check ALL of your fuses again. If the elec. windows were rigged up then you never know what other items the previous owner may have rigged up.
    If you trace the grounds of all the accesories you will find that they all are joined in one junction on the drivers side kickpanel right up under the dash. one short in one accessory can cause others to fail.
    Good Luck!
    Justin
    Austin, Texas K5'er
