Electrician needed
Discussion in 'Rocky Mountain Region' started by BLZN4FN, Oct 7, 2006.
  1. BLZN4FN
    BLZN4FN 1/2 ton status
    Dec 19, 2000
    1,720
    Englewood Colorado
    I bought a used air compressor off Craigs list but the motor was not wired. So I tryed to hook up the green,white,brown wire. It turns on but the motor does not spinn fast enough. So if you know how to wire my Compressor or know of a person that can please let me know.
  2. nutsthename
    nutsthename 1/2 ton status Premium Member GMOTM Winner
    May 29, 2006
    350
    Pageland, SC
    Is it a dual voltage motor? 110/220?
  3. 3 on the tree
    3 on the tree 1/2 ton status
    Oct 16, 2004
    3,970
    gunnison colorado
    Is it a belt drive? If it is, try removing the belt and firing it up. Does the motor turn over by hand freely? Maybe bad bearings. If its dual voltage, should be marked on the cover.
  4. bowtiepower00
    bowtiepower00 1/2 ton status
    May 11, 2000
    924
    AZ
    Sounds like you're running a 220V motor at 110V. Though it's difficult to say w/o looking at it. If the motor is rated at 110 and it's running too slow, I would imagine that you'd smell or see burnt windings or something of the like. Are you running two separate 110V legs and one neutral/ ground?
