Electronic spark
Discussion in 'The Garage' started by shaun, Mar 22, 2004.
  1. shaun
    shaun 1/2 ton status
    Apr 22, 2003
    745
    What is wrong with my truck. It keepsshowing my check engine light but by the time I get it to the shop to run the codes they are gone and it says there are no trouble codes. I have caught it once and it said it was an electronic spark control problem. I have replaced the plugs, wires, coil, cap, and rotor and am putting in a msd box. But why does it keep showing my check engine light and then clearing it. It also cuts out every /forums/images/graemlins/1zhelp.gif /forums/images/graemlins/k5.gifnow and then like it is being starved of fuel. But I believe that is the filter or pump because it will do that without throwing a code. But it also cuts out when the service engine light comes on. Why???????????
  2. btolenti
    btolenti 1/2 ton status
    Sep 28, 2003
    644
    Gilroy, CA
    bad pickup coil in distributor...
    bad knock sensor...
    bad catalytic converter...
  3. djsblaze
    djsblaze 1/2 ton status
    Jul 7, 2003
    318
    Oklahoma
    Im having a similar problem. My light goes on and off as well, and engine dies periodically, usually under pretty heavy throttle during acceleration. Ive checked the plugs, distributor, etc. Thanks.
  4. shaun
    Apr 22, 2003
    745
    That sounds identical to mine. It also stumbles every now and then Driving but if I let it sit for about a min all is good. I am lost. What should my knock sensor read on a scanner if it is good? bad? It did this with my old coil in there and the new one is an msd gm so I dont know? /forums/images/graemlins/dunno.gif /forums/images/graemlins/dunno.gif
