electronic speedometer& tranny swap
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by angrysnowplow, Jan 11, 2002.
  1. angrysnowplow
    angrysnowplow 1/2 ton status
    Jan 8, 2002
    502
    MA
    The specs area of the site tells me my 90K5 (700R4) has an electronic speedometer. Just wondering if anyone could tell me if it could be adapted to work with the SM465 I intend to swap in? Thanks in advance.
    1990 Blazer 350, 700R4, NP241 -soon to be sm465+208
  2. 95 Silverado
    95 Silverado 1/2 ton status
    Nov 9, 2001
    467
    Central PA
    the electronic speedometer pick-up is actually on the transfer case tailshaft, they say a 208 and 241 bolt to the same adaptor, if you change your transfer input gear to a 32 spline gear, you should be able to use your transfer case with the 465 & 208 adapter, I don't know if they made a 208 with the electronic speedo set-up. (if you need a 465 transmission with an NP208 adapter I have one)
    '95 Chevy Silverado 1500
    5.7 V8-NV4500- 3.73 rears
    <P ID="edit"><FONT class="small">Edited by 95 Silverado on 01/11/02 05:04 PM.</FONT></P>
