electronical problem 88 k5
Discussion in 'The Garage' started by muddybuddy, Mar 16, 2005.
  1. muddybuddy
    muddybuddy 3/4 ton status
    Jan 29, 2004
    8,933
    Fairfax Station VA
    i have a 88 k5 and when its running, the battery guage is just a little past the red zone on the negative. sometimes after a while it will go to the normal spot in the center, but after a couple minutes it goes back barely reading anything. i have replaced the battery and alternator. i was thinking maybe its short circuiting? :confused: i really dont know . what should i check? any help is much appreciated. thanks
  2. Mantruck-k5
    Mantruck-k5 Registered Member
    Feb 16, 2005
    18
    Fairfield CA
    Meter
    Get a voltmeter and see what your alternator is putting out with your engine running. If it reads above 13.5 or so you're good to go. Could be a bad guage...
  3. blackblazer717
    blackblazer717 1/2 ton status
    Jul 1, 2004
    470
    massachusetts
    i think its the wiring going to the guage or the guage itself because i had that problem. or its the IVR thats messing with it just get a voltage reading on the battery with it running!
    luke
