elelectronic ignition systems.
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by riz, Jun 8, 2000.
  1. riz
    riz 3/4 ton status
    Mar 7, 2000
    6,026
    Wisconsin
    I'm about to install an MSD 6A ignition system in my Blazer but don't know where to put it.....The only place it looks like it will go is on the inner fender well, but even there it would need some sort of bracket made. On the fire wall there isn't room either due to the air conditioning stuff. I want to put it on Saturday morning, so if you guys could reply quickly it would be appreciated. Also, any pictures of where you put yours would be great. Thanks !
    L8r,
    .Riz.
  2. BlazerGuy
    BlazerGuy 3/4 ton status
    Apr 20, 2000
    9,206
    abcde
    I helped my friend install a 6AL is his K5. He made a bracket to mount it on the fender well out of aluminum. Sorry, I cant get a pic though(he lives out-of-state).
    http://www.blazer.coloradok5.com is now under construction[​IMG]
    YEEEE HAWWWW[​IMG]
  3. Depdog
    Depdog 1/2 ton status Author
    1,657
    Georgia
    Well, I cut the inside out of my glove box and mounted mine on the a/c box in the cab. Just open the glove box door and there is it. Go to www.off-road.com and go to the chevy section, look for the article on the Crane Ignition for pics.
    Depdog
    <font color=blue>"Lead, Follow, or BECOME the Trail"</font color=blue>
  4. J.R.
    J.R. Guest
    i put mine on the drivers side innerwheele well,you can use shims or washers to level it off,the main thing is to put it as far from exhaust manifold as you can.mine has been on for 5-yrs now never had a problem.goodluck..
    BIGBLOCK MAN
  5. BlazerBoy
    BlazerBoy 1/2 ton status
    639
    Chicago IL.
    I was able to lay mine flat right on the inner fender well near the windsheild washer fluid tank and put 4 bolts through the fender with the nuts on the msd side.. easy as can be..
    BlazerBoy
    http://generalblueballs.coloradok5.com
  6. Emmettology 101
    May 9, 2000
    8,126
    FL
    I mounted mine on the passenger side fender right beside the battery.
    Sorry I dont have pics either.
    Mike
    1982 GMC Jimmy - Emmett
    http://emmett.coloradok5.com
