Eletric fuel pump
Discussion in '1982-Present GM Diesel' started by josephn, Jun 10, 2002.
  1. josephn
    josephn 1/2 ton status
    Nov 3, 2000
    138
    Utah
    Can you use any eletric gas inline fuel pump on a 6.2 for a lift pump? If so does anyone know the psi required?
    Or do you have to get one that is specificly for the diesel?
    Just curious.
  2. René
    René 1/2 ton status
    Mar 14, 2002
    208
    Michelbach, Germany
    ... without problems...
  3. josephn
    Nov 3, 2000
    138
    Utah
    Do you mean that you have done this with no problems?
  4. BlueBlazer
    BlueBlazer 1/2 ton status
    Feb 15, 2001
    1,940
    Yes you can do it, Ive had mine on for over 2 years, helps in case I run out of fuel and as a backup for the mechanical lift pump. Just get something low pressure for a carbureted engine and youll be fine.
  5. René
    René 1/2 ton status
    Mar 14, 2002
    208
    Michelbach, Germany
    That is it. I relieve my injection pump with this system, because I drive with pure vegetable oil (no Diesel). Functioned really fine.
  6. josephn
    Nov 3, 2000
    138
    Utah
    Straight Vegtable oil? What kind do you use and did you have to do any engine mods or additives to get it to run?
    I would like to try this how would I go about doing it?
  7. cegusman
    cegusman 3/4 ton status
    Apr 25, 2001
    6,793
    Houston/Katy, Tx
    Does it matter where you put it in line? (Close to engine or close to tank)
  8. BlueBlazer
    Feb 15, 2001
    1,940
    It really shouldnt matter since youre really just assisting the mechanical pump. I have it on the frame rail about where the passenger door is and that seems to work fine.
  9. calcide
    calcide 1/2 ton status
    Dec 21, 2001
    283
    IMHO, it's a bad idea to run an electric pump ahead of your mechanical pump. Run one or the other. It's possible that if you run both, if the rubber diaphragm in the mechanical pump ruptures then your electric pump can pump your crankcase full of fuel. It may not be likely, but still a possibility.
    As for running on straight vegetable oil, it's not too difficult or uncommon. Start a new thread on the topic and I'll tell you what I know... <font color="blue"> /forums/images/icons/grin.gif </font color>
  10. RLBstein
    RLBstein 1/2 ton status
    Jul 2, 2000
    179
    Pensacola, FL
    Just run it as close to the tank as possible. An electric fuel pump does better pushing the fuel than pulling it. You are also correct about the diaphram on the manual pump could go bad and the electric will pump fuel directly into the crankcase. I haven't had any problems with mine, but then again my dad just emptied 6 quarts of fuel from his crankcase because his manual pump went bad, and he isn't even running an electric pump in line. I have noticed a lot better startup since I put the electric one on. Waiting for the glow plugs gives the pump enough time to have the fuel ready to be burned.
