eletrical question
Discussion in 'The Lounge' started by surpip, Apr 13, 2007.
  1. surpip
    surpip 1 ton status
    Apr 7, 2004
    10,877
    sacramento ca
    Our shop truck is a 34 ford with a flad head, the eletricla system was converted to 12v but there is still a lot of 6v stuff on there, like the wiper motor.
    I used an old reostat to try to knock the voltage down, but it is still to much for the motor.
    My question is, what size resitor do i need to wire in line to make the voltage drop from 12 to 6-8v?
  2. skyyk5
    skyyk5 1/2 ton status
    Jan 2, 2007
    1,537
    N.E. PA
    They have stuff out there for that. JC Winteny has a voltage drop just for that. And might find more info in the garage.
  3. surpip
    surpip 1 ton status
    Apr 7, 2004
    10,877
    sacramento ca
    ya i ment to post this in the garage
    Paging mods:)
  4. mofugly13
    mofugly13 1 ton bucket of rust Premium Member
    Oct 6, 2002
    2,813
    San Francisco
    Take a look at this page
    http://www.the12volt.com/ohm/ohmslaw.asp
    You need to get a current reading off the wiper by running it from a 6V source and measuring the current draw. Then plug that into R=6/I and that will give you your resistor value. That's how it works in general DC circuitry, but I am not sure how it applies to automotive wiper motors. You can find the appropriate formula on that same page to figure out the needed power rating (watts) for the resistor as well.
  5. surpip
    surpip 1 ton status
    Apr 7, 2004
    10,877
    sacramento ca
    thats the big problem, is finding a 6 volt source
    I might just use a old ballast resistor
  6. kgillyk5
    kgillyk5 1/2 ton status
    May 29, 2003
    1,830
    Fultonville, NY USA
    That's really it...The last part is really important. Just knowing the resistance is great but the resistor needs to be able to disipate the heat (volts X amps=watts) that the current is producing.
    Oh ya, I=Amps...nobody tells you that.
  7. 84k5
    84k5 1/2 ton status
    May 13, 2000
    2,949
    Dublin, CA
    Call the engineering department of the manufacture of the wiper motor and get a recommendation. Then you have a scapegoat when the car catches on fire.:wink1:
  8. surpip
    surpip 1 ton status
    Apr 7, 2004
    10,877
    sacramento ca
    you bet
    that will work great, since the truck in a 1934
    I'm sure the guy that designed it is still alive
  9. kgillyk5
    May 29, 2003
    1,830
    Fultonville, NY USA
    If the things worth anything, I say get a 12 volt wiper system or whatever other accessories you need. Will make working on it later easier. I've got a linkage and 12v wiper motor from a 94' furd probe you can have.
  10. surpip
    surpip 1 ton status
    Apr 7, 2004
    10,877
    sacramento ca
    no its need to be the stock motor
    here is the truck
  11. kgillyk5
    May 29, 2003
    1,830
    Fultonville, NY USA
    Man, I love that thing...saw it in some other post before. I was thinking like a big ol' service truck or something.:haha::haha:
    Ya, go original. So the start and charge is all 12 volt??? Need dc to dc converter at the right wattage to run acc....Cool.:D
  12. 84k5
    84k5 1/2 ton status
    May 13, 2000
    2,949
    Dublin, CA
  13. surpip
    surpip 1 ton status
    Apr 7, 2004
    10,877
    sacramento ca
    it worked
    I called you out to search for me
    heheheh
    thanks dood
    although i am pretty sure no one at a ford dealership would be able to look up the specs on that old of a part
  14. kgillyk5
    May 29, 2003
    1,830
    Fultonville, NY USA
  15. surpip
    surpip 1 ton status
    Apr 7, 2004
    10,877
    sacramento ca
    awsome, thanks guys for the help
  16. RustyParts
    RustyParts 1/2 ton status
    May 26, 2005
    235
    Wyman, Kentucky
  17. surpip
    surpip 1 ton status
    Apr 7, 2004
    10,877
    sacramento ca
    no an option, my boss is cheap
  18. CustomChevy
    CustomChevy 1/2 ton status
    Jun 29, 2005
    4,328
    Kitchener, Ontario, Canada
    steal a squeegy from the local gas station
    problem solved.
  19. RustyParts
    May 26, 2005
    235
    Wyman, Kentucky
    Well, if your boss is too cheap, using Ohms law if the windshield motor is pulling say 15 amps, on a 12 volt system you would need a .8 ohm resistor to drop six volts.
