eletricians alert
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by noJeepshere, Feb 6, 2003.
  1. noJeepshere
    noJeepshere I Drive Trains! Premium Member
    Jan 2, 2003
    8,594
    765
    City of Sand, UT
    /forums/images/graemlins/1zhelp.gifi have a a gauge cluster out of a 79 truck that i want to put in my jimmy. after doing some research, i found that the idiot light dash uses diaphrams to work the light, and the gauge dash uses voltage regulators to work the gauge. my question is, will replacig the diaphram with the regulator work? i really do not like not knowing i have low oil before its too late /forums/images/graemlins/angryfire.gif, so any help would be nice. /forums/images/graemlins/ears.gif
  2. 95 Silverado
    95 Silverado 1/2 ton status
    Nov 9, 2001
    467
    Central PA
    I'm not sure I fully understand but I will take a guess. The two different clusters use different types of senders, an idiot light uses an on/off switch set at a specific temp or pressure. it turns the light on or off. the gauge sender uses a variable resistor to vary the voltage back to the gauge in reference to the pressure or temperature. you need the correct senders to match the cluster you are using. The wiring is basically the same, but if you use a cluster from a different year vehicle there may be a difference in location of the wires in the cluster plug. Someone else on here may know the specifics on that. As for the senders, just get the gauge type sender and install it in place of the idiot light sender.
  3. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
    yeah your differences wil bne in the sendig units screwed into the driver side head and differences in sending unitsfor oil sometimes
  4. noJeepshere
    Jan 2, 2003
    8,594
    765
    City of Sand, UT
    THanks guys, found the senders and replaced them. im working on changing the speedo gears in the t-case to compensate for the different numbers on the face, mine goes to 85mph the "new" one is a 100mph guage. just got to replace the motor now. 4.1 L6, anyone? /forums/images/graemlins/pimp1.gif
