ELocker install problems
Discussion in 'The Garage' started by driney, Nov 28, 2004.
  1. driney
    driney 1/2 ton status Premium Member
    Jul 6, 2001
    699
    7
    west central illinois
    I'm in the middle of installing an ELocker in my 1o bolt front axle. I hoped the shims I had were close but they seem to be about 3/32" to thin to preload the bearings. Is it normal to have to shim that much over the original installation? Also can I find the shims locally or is that something I'll have to order? I'm about 1 1/2 weeks away from an OK trip and I have a ton of work to do yet. /forums/images/graemlins/1zhelp.gif
  2. readymix
    readymix 3/4 ton status
    May 30, 2004
    6,706
    26
    Murrieta, California
    You should be meausring shims by the .001" not by 1/32 scale.
    But onto your question. I have only regeared one 10 bolt that the original production shims worked on. The other 4 needed to be shimmed to get the backlash correct. You should be able to get the shims at an NAPA or Pep-Boys. If not there try a dealership. I keep a box of shims and old bearings in my garage just for those occasions. If you could tell me the thickness of shim you need such as .024 i could mail you some in the morning.
  3. driney
    Jul 6, 2001
    699
    7
    I may have partially solved the problem. The new races were one digit off in the part number. I think the correct races will be thicker. Thanks for the help. /forums/images/graemlins/thumb.gif
