emblem install/removal help please
Discussion in 'The Garage' started by johnnieg, Apr 19, 2004.
  1. johnnieg
    johnnieg 1/2 ton status
    Nov 10, 2002
    130
    CSU, Ft. Collins, CO
    How do you remove and install the fender and "silverado" emblems? I tried to reach in through the engine compartment but can't reach. One K-5 emblem was already smashed so I just pried the rest of it off with a screwdriver. Do they snap in or use those speed nuts? thanks everybody.
  2. BlazerGuy
    BlazerGuy 3/4 ton status
    Apr 20, 2000
    9,206
    abcde
    I just rubbed up against a tree and they fell right off...actually the "Bl" part stayed on the "azer" part fell off... /forums/images/graemlins/grin.gif
  3. chevyfumes
    chevyfumes Court jester
    Feb 24, 2000
    38,584
    266
    Watch for the muzzleflash!
    /forums/images/graemlins/histerical.gif /forums/images/graemlins/histerical.gif /forums/images/graemlins/histerical.gif /forums/images/graemlins/histerical.gif
  4. johnnieg
    Nov 10, 2002
    130
    that's exactly what happened to me. But I mean without destroying the emblems. /forums/images/graemlins/thumb.gif
  5. cacabrown
    cacabrown Newbie
    Apr 19, 2004
    3
    If you cant find a new/used emblem they have all of them in LMCTRUCK.com catalog /forums/images/graemlins/k5.gif
  6. Muddytazz
    Muddytazz 1 ton status
    Jun 30, 2002
    20,073
    Salem, Or.
    Most of the older ones are held on by those cheesy speed nuts. The newer ones are held on with sticky glue-tape crap.
  7. lukebaby1
    lukebaby1 1/2 ton status
    Dec 16, 2003
    231
    Richmond, Virginia
    The K5 front emblems can be a little tricky. I always end up replacing them. The ones after 1980 are really cheap and break at the slightest stress. I ended up replacing the ones on my 1984 with the cast monkey metal ones from the 1st generation type blazers. They are much better and look cooler. You have to drill a couple of extra holes, but done right they work great. Instead of using speed nuts, (because of the access to the inside of those particular panels) I used some Plumbers Goop, which is a sort of clear acrylic glue that dries hard and clear. I just put it liberally on the mounting pins and then affixed it tell it dried good. As for the rear Silverado emblem, you can access those speed nuts through the tailight housing opening. You just have to go to the trouble of removing the tailight, and housing. /forums/images/graemlins/waytogo.gif /forums/images/graemlins/waytogo.gif /forums/images/graemlins/smile.gif /forums/images/graemlins/smirk.gif
