Emblem removal...how?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Rix_Gotta_Blazer, Aug 27, 2002.
  1. Rix_Gotta_Blazer
    Rix_Gotta_Blazer 1/2 ton status
    Dec 13, 2001
    104
    Hollister, CA
    The'81 is gettin painted in 2 weeks. I am in the process of doing the prep work. I was able to remove all emblems except for 2. The 2 are the "K-5 Blazer" emblems on both of the front fenders. is there some sort of tip or method anybody could give me to remove these? any input is greatly appreciated, thanks.
  2. JK5
    Jan 31, 2002
    3,453
    Norton, Oh
    They are held on by nuts.....You have to pull the hood and hinges to get to them.....or take a sharp puddy knife and tap on it with a hammer carefully and shear the studs on the emblem.....Since they are made from "White-metal" they shear easily.....After the paint job...glue or apply double sided tape them.....I never bolt them back on!!!
  3. Blue85
    Blue85 Troll Premium Member
    Jul 26, 2000
    9,089
    489
    Grand Rapids area
    Something to consider is filling those holes for the paint job. Emblems aren't necessary anyway and detract from a clean look unless they are in great shape. You can hold most of them on with 3M two-sided trim tape. That is what holds most of the emblems on newer cars. All holes are just opportunities for rust.
  4. 83PJW
    83PJW 1/2 ton status
    Aug 18, 2002
    160
    leavenworth, ks
    i removed mine by getting real close to a tree and... no just kidding if it comes down to it just order new ones from lmc catalog they are dirt cheap.
  5. bryguy00b
    bryguy00b 3/4 ton status
    Apr 7, 2002
    5,587
    Rochester, N.Y
    well i didnt have to worry bout removing mine..they just rusted there way of...hahah /forums/images/icons/blush.gif /forums/images/icons/grin.gif
  6. BigBadCad
    BigBadCad 1/2 ton status
    Dec 18, 2001
    109
    minneapolis, mn
    I also think you should pull the tags, weld, and fill those holes. I like the clean lines of a truck with the emblems, trim, and wheel mouldings removed.
  7. Rix_Gotta_Blazer
    Dec 13, 2001
    104
    Hollister, CA
    My method worked perfectly, Break them off and don't look back. they looked like junk after 21 years anyway. Thanks for all the insight fellas.
