emergency brake light wont go off
Discussion in 'The Garage' started by Guss, Sep 14, 2005.
  1. Guss
    Guss Registered Member
    Feb 6, 2005
    78
    houston
    any one know how to reset the brake light in a 90 blazer
    replaced the brakes and rotors back not even close to worn.
    but i wore the fron way farther than i sould have now brake light wont go off.
    do i just disconect the battery for a period and if so how long?
  2. dyeager535
    26,982
    191
    Only two things trigger the brake light: Switch at the brake pedal is messed up, or the proportioning valve has turned it on. OK, three: wiring issue.
  3. dremu
    Feb 27, 2000
    15,970
    462
    East of San Francisco
    Is it *blinking*, or on steady?
    If it's on steady, you're low on brake fluid or the p-valve (as Dorian points out) thinks you are, the switch on the parking brake is horked, or there's a wiring problem.
    If it's blinking, that's an ABS code and is a whole other ball of wax.
    -- A
  4. Leper
    Leper 1/2 ton status
    Feb 18, 2005
    4,437
    Dallas Baby!!!!
    unplug the controller near the master cylinder and plug it back in. Fixed 2 trucks this way. Check the fluid level. Flushing the brakes not a bad idea either.
  5. JIMs70K25
    JIMs70K25 1/2 ton status
    Dec 31, 2001
    524
    Chesapeake, VA
    Not sure if it's the same but on both my 70s, I had to brake hard to reset the p-valve, and the light went out. Also the wire could be disconnected from the p-valve.
  6. Guss
    Feb 6, 2005
    78
    houston
    ok its a solid light and i checked the wire on the portioning valve witch
    A. conected tightly
    B. free of corrosion
    but i know my e-brake pedal does work( doesnt lock when applied) ill check the switch there and let you guys know.
  7. Guss
    Feb 6, 2005
    78
    houston
    got the e-brake to latch now working. light still on and only gets brighter
    when e-brake is pushed. i pulled the release and it stays on but dims
    cheked switch and found no problems
    AAAAAAAHHHHHHH!
  8. Rob 85K5
    Rob 85K5 1/2 ton status GMOTM Winner
    1,487
    Pensacola, Florida
    Check your fluid.
  9. Guss
    Feb 6, 2005
    78
    houston
    fluid is full and pretty clean
  10. Guss
    Feb 6, 2005
    78
    houston
    what do you mean unplug next to master cylinder? are you talking about
    the sensor?
  11. dremu
    Feb 27, 2000
    15,970
    462
    1990-91 R and V series trucks (don't ask, but it includes your Blazer, presuming it's a full-size) have rear-wheel anti lock brakes, aka RWAL or ABS.
    There's a black plastic box somewhere around your master cylinder, which is the computer that controls this mess... that's why I asked if it was a BLINKING light, indicating a problem with this system, or a SOLID light, generally indicative of the rest of the (normal) system.
    -- A
  12. Guss
    Feb 6, 2005
    78
    houston
    ok ill try unplugging i thought it was the ecm :rolleyes: the battry reset wont work for this though?
  13. Guss
    Feb 6, 2005
    78
    houston
    it worked thanks alot
  14. Leper
    Feb 18, 2005
    4,437
    Dallas Baby!!!!
    I was assuming your 90 looked like my 91. There is a controll unit mounted my master cylinder with a couple of large connectors on it.
  15. 91BurbDude
    91BurbDude Registered Member
    Dec 17, 2005
    16
    North Carolina
    I have a 91 Burb with this same problem. I also checked the e brake switch but found the same thing that when the e brake release is pulled the light stays on but not as bright. I will try the unplugging thing tomorrow. I knew if I searched the forums I would find someone with the exact problem I have! LOL
  16. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
    I had to reach under mine Monday , and hammer the bracket back in place , and tug tje cable a bit to free it , so my pedal would go back up and turn the light out ...... *** **** ROCKS :D
  17. Guss
    Feb 6, 2005
    78
    houston
    just reset the computer on the master cyl. and it will be fine
