emergency fuel pump switch
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by k5blazerholic, Sep 1, 2003.
  1. k5blazerholic
    k5blazerholic Newbie
    Jul 19, 2002
    3
    i Have a 1991 k5 blazer and after my wreck i cant get it to start because i cant find the emergency fuel pump shut off someone please help!!!!!
  2. Grim-Reaper
    7,385
    Atlanta
    Uhhhh This sure would get more attentions in the garage....I don't think there is one. I think that was a mid 90's deal. No where in my factory shop manual is one mentioned for my 88.
    I would start by checking fuses. If all is good then put a meter or testlight on the power lead to the pump. WHen the truck is first turned to run the pump should cycle for 5 seconds to build pressure. Have somebody turn the switch while you check for power. If you got power the the pump is proably hosed.
    If you have no power then you need to figure out why. Could have pooped a fusable link in the wreck.
  3. Derf00
    Derf00 1/2 ton status
    Jul 25, 2000
    1,683
    Abilene, TX
    Just below the fuel pump relay there is a connector that you can run a circuit to this connector and it will activate the fuel pump.
