emergency fuel pump
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by k5blazerholic, Sep 1, 2003.
  1. k5blazerholic
    k5blazerholic Newbie
    Jul 19, 2002
    3
    I have a 1991 k5 and after my wreck i cant get it to start because i cant find the emergency fuel pump shut off switch and it is driving me crazy i have looked in the kick panels and dash someone please help thank you
  2. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    Sure that's not a Bronco you're driving? GM doesn't use intertia switches as far as I know. Good luck finding your problem.
  3. AZ_Overdrive
    AZ_Overdrive 1/2 ton status
    Dec 18, 2002
    117
    Arizona
    I had a similar problem one morning. My 89 Burb would not start. Checked the injectors and no fuel. Turned out to be a bad coil. The computer shutoff the fuel pump. Oh, and no trouble light came on due to the bad coil.
  4. Can Can
    15,552
    136
    Cochrane, Alberta, Canada
    I believe there's also an oil pressure switch involved in the picture. If the switch is shot or isn't reading properly your fuel pump won't engage.
    Just throwing an idea out. Keep us posted, brother.
  5. 4X4HIGH
    Dec 14, 2001
    22,060
    69
    Pleasanton, CA.
    The pressure switch you speak of is actually in case the fuel pump relay goes bad it will allow the fuel pump to continue working as long as there is oil pressure.
  6. Can Can
    15,552
    136
    Oh well, I tried...... /forums/images/graemlins/crazy.gif
    What do you think might be causing this problem?
