Emergency Help Please!(got it, thanks)
Discussion in 'The Garage' started by RampageFSJ, Oct 19, 2006.
  1. RampageFSJ
    RampageFSJ 1/2 ton status
    Aug 18, 2005
    121
    Ulysses KS
    I have a friend's blazer here that has a worn rear U joint that is basically busted. He has to leave for practice in 2 hours. This is an 85 blazer that has the kind of u joints without a snap ring. I might have a spare that he can use. I have never taken these things apart so I need some help. How do you take it apart without a press? Use a hammer? Any special tricks? Thanks in advance for any help given.
  2. uberbeans
    uberbeans 1/2 ton status
    May 14, 2004
    564
    Jacksonville, Florida
    Use a c-clamp and a socket to press the caps through after liberally doseing it with penetrant. Then do it again to install. Sometimes you have to hammer it a bit, too. Good luck!
  3. SkulzNBonz
    SkulzNBonz 1/2 ton status
    Feb 20, 2002
    4,522
    OKC, Oklahoma
    Hammer and an socket slightly smaller than the caps.
    John
  4. RampageFSJ
    Aug 18, 2005
    121
    Ulysses KS
    won't both of those options push the cap that I'm applying pressure to in farther?
  5. 73k5blazer
    Dec 28, 2001
    4,987
    38
    The Rustbelt
    Well, a regular c-clamp, yes. I use my ball joint tool, which is a very heavy c-clamp with the end hollowed out, so the cap pushes thru it. You will have to get creative in your vise or with the hammer and 2 different sized sockets.
    One socket smaller that the dia. of the cap to push it thru, and one socket larger than diameter so it holds the yoke but allows the cap to fall thru.
    Vise is good to install, or hammer and socket. If you use anything jarring to install, you need to take care not to dislodge the needle bearings in the cap before they are engaged on the joint, somtimes they fall down, and you can't get the cap to go all the way on, because a needle bearing is stuck laying down in the bottom of the cap.
  6. nutsthename
    nutsthename 1/2 ton status Premium Member GMOTM Winner
    May 29, 2006
    350
    Pageland, SC
    Sounds like it has nylon locks. If you have a torch use it to melt the locks. Then press it out like a u-joint with external locks.
  7. RampageFSJ
    Aug 18, 2005
    121
    Ulysses KS
    allright, thanks for the help. I ran out of time and had to run him to practice myself. He had me pick up a new joint, which is now in there. No I just wanted to know what kind of fluid I should put in the NP208. All I have is normal fluid, does there need to be any tranny fluid or anything special in it? (Sorry, my quadra trac on my jeep takes a tranny / normal fluid mixture, so that's why I'm asking.)
  8. randy88k5
    randy88k5 1/2 ton status
    Nov 8, 2004
    1,248
    Lynchburg, VA, USA
    The 208 just takes regular ATF, Dexron III/Mercon
  9. RampageFSJ
    Aug 18, 2005
    121
    Ulysses KS
    Thank you, and my friend says thank you very much.:bow:
  10. CDA 455
    CDA 455 3/4 ton status
    Jun 2, 2006
    8,598
    43rd State
    Or, just unbolt the rear drive shaft and lock the front hubs.
  11. randy88k5
    Nov 8, 2004
    1,248
    Lynchburg, VA, USA
    The 208 has a slip yoke. If he drives too far without the shaft, he will lose all the fluid out of the Tcase. It would be easier and cheaper to fix the ujoint then to risk a Tcase rebuild.
  12. scooter122983
    scooter122983 1/2 ton status
    Oct 4, 2006
    297
    Fond du Lac, WI
    Like he said the 208 has a slip yoke that will get you about a mile down the road and you will have no more fluid. Especially since the 208 is a all time unit the rear shaft will be throwing fluid all over the place. REALLY SMART
  13. DirtyJim
    DirtyJim 1/2 ton status
    May 4, 2005
    665
    San Diego
    front wheel drive
    i have gotten home many times with front wheel drive
  14. kgillyk5
    kgillyk5 1/2 ton status
    May 29, 2003
    1,830
    Fultonville, NY USA
    My 90' K5 has the same type joints. Can u replace them w/ conventional external clip type joints?
  15. RampageFSJ
    Aug 18, 2005
    121
    Ulysses KS
    Not that I could tell, I finally found out that there is a clip holding them on at the base of the cap, close to the body of the joint. The caps were so screwed up from breaking that I didn't notice it.:rolleyes:
  16. RampageFSJ
    Aug 18, 2005
    121
    Ulysses KS
    Before I forget, here's the bad joint. I wouldn't let him leave my driveway with it:eek1: . What's even more amazing, is that he had driven on the highway before he showed up at my house:yikes: . Sorry for the blurry pic.
