emergency please
Discussion in 'The Garage' started by stiches, Nov 22, 2005.
  1. stiches
    stiches Registered Member
    Nov 16, 2005
    72
    vallejo/lodi, CA
    Just changed my alternator...
    hooked everything back up right...went to start it a loud scraping sound is heard and smells like something is burnin bad...but i see no smoke or anything...PLEASE help
  2. gman454
    gman454 Registered Member
    Sep 23, 2005
    45
    East Hartford, Connecticut
    is the belt to tight or to loose
  3. stiches
    Nov 16, 2005
    72
    vallejo/lodi, CA
    I useed a scrrew driver and pryed it up farther and started it...to tight..
    i dident know a belt could be too tight...
    i think its a belt
  4. gman454
    Sep 23, 2005
    45
    spin the engine by hand make sure you didnt reck the belt in one spot.if you did it could possably jump off at higher rpm or even ruin the bearings in the alternator good luck :D
  5. stiches
    Nov 16, 2005
    72
    vallejo/lodi, CA
    I fixed it it turned out the orignal belt was too short or small ...wrong size...i went out and got a slightly bigger one and its working...yay i have a car again
  6. gman454
    Sep 23, 2005
    45
    good to hear have a great holliday :D
  7. stiches
    Nov 16, 2005
    72
    vallejo/lodi, CA
    thanks....does anyone have a picture of what the stock 350 engine loooks like?
  8. Roz
    Roz 1/2 ton status
    Mar 27, 2005
    900
    San Diego
    what year and installed or out? :hack:
  9. stiches
    Nov 16, 2005
    72
    vallejo/lodi, CA
    1978 350 installed...and out if possible
  10. Roz
    Roz 1/2 ton status
    Mar 27, 2005
    900
    San Diego
    mines not stock but its a 79, dont know if that will help. the vac lines are a bit different
  11. cbbr
    Jul 17, 2004
    14,681
    High velocity, Low altitude
    FYI - Scraping sounds and burning smells are not normally an indication that things are hooked up right. :D
