emission problems???
Discussion in 'The Garage' started by chops76, Jan 30, 2006.
  1. chops76
    chops76 Registered Member
    May 6, 2005
    38
    south elgin, il
    gotta 1976 k5 with a 350 and a carter abf comp. carb. i am not sure on the size of the carb. but i leaned the sucker out as far as i could and the test results were hydrocarbons at 700 which i guess is at 3 times passing limit. engine has undergone tune up(plugs , wires, cap, rotor?.. any suggestions before suspension? thanks
  2. stkcode
    stkcode Registered Member
    Nov 30, 2005
    86
    Apple Valley, CA
    When you did your tune-up, did you also check your timing?
  3. thfonz98
    thfonz98 1/2 ton status
    Feb 19, 2005
    319
    Salinas, ca
    replacement of the cat. converter possibly.
    my former s10 blazer was at 1000+ then i did the full tune up thing and dropped to 700ish then the new cat dropped it to 8! Cat didnt seem plugged and didnt smell, it just didnt work
