Emission question 6.2 88'
Discussion in '1982-Present GM Diesel' started by woods, Feb 18, 2003.
  1. woods
    woods Registered Member
    Feb 18, 2003
    73
    Emission question 6.2 88\'
    Just recently got an 88' k5 blazer 6.2, and when comparing to my dads 6.2 85 burben. He doesnt have a big friggin EGR thing blocking 3/4 of his air intake. I'm wondering if I can possibly take all that crap off to increase my air flow to engine.
    Woods
  2. Judd
    Judd 1/2 ton status
    Sep 27, 2002
    175
    N.E. Ga
    Re: Emission question 6.2 88\'
    You can pick up a heavy truck/ military intake that doesn't have it. They are actually quite common. Look at a the big box vans{Lays Potato Chip Vans almost always have 6.2/6.5s in them}. If I remember right, they are called P30s or something like that.
  3. woods
    Feb 18, 2003
    73
    well couldnt I just use my old intake and take off that EGR thing? I'm just wondering if there will be any side effects to taking it off, trying to find a manual to see what it excalty does.
    woods
  4. Tybee
    Tybee 1/2 ton status
    Mar 25, 2001
    1,565
    Centennial, CO
    Dont take it off, alot of people plug the vacuum line that goes the the egr valve and have less smoke from the exuast. The heavy duty intake manifold has a larger opening with the egr mount and passages not cast in.
  5. arveetek
    arveetek 1/2 ton status
    Mar 1, 2002
    722
    Granby, MIssouri, USA
    Yes, you can take it off. You'll need to plug the hole underneath the EGR with an engine block freeze plug....I forget the exact size. There are exhaust gases running between the two heads in the intake directly underneath the EGR valve. If you remove the valve without plugging the hole, exhaust gases will escape into the intake.
    There are two versions of the 6.2L....a light duty and heavy duty. The light duty is known as a "C" code, due to the C designation in the VIN. The heavy duty is known as a "J" code, for the same reason. The J code motors don't use an EGR. You can simply get a J code intake and bolt on in place of your C code.
    There are two versions of the J code manifold, neither using an EGR setup. The pre '88 models are a dual plane, with a divider in the center. The '88 and later models are better and more free flowing with a single plane, completely open plenum....that is what I have on my '81. Most 3/4 and 1 ton trucks use J code engines. Either version are better than the restrictive C code intakes.
    Casey
  6. Tybee
    Mar 25, 2001
    1,565
    Centennial, CO
    Much better said! /forums/images/graemlins/thumb.gif
  7. woods
    Feb 18, 2003
    73
    THANKS just the info I was looking for, and those j code intakes can be brought at thediesel page correct?
    Woods
  8. arveetek
    Mar 1, 2002
    722
    You can purchase a used J code intake from The Diesel Depot, a Diesel Page supporter. The Diesel Page doesn't actually sell any products, other than reference materials.
    Casey
  9. Tybee
    Mar 25, 2001
    1,565
    Centennial, CO
    Look on ebay they are on there all the time.
