emissions/carbs/motors.......will it ever end
Discussion in 'Rocky Mountain Region' started by teamhickman, Apr 9, 2005.
  1. teamhickman
    teamhickman 1/2 ton status
    Aug 28, 2004
    226
    Buckeye, AZ.
    emissions/carbs/motors*****IT PASSED*****
    It passed :woot: The idle HC went from 1026 to 250!!!!!
    This is great!!!!!!!
    Thanks to Mosesburb......I did "richen" the mixture as suggested and apparently it worked!
    Thanks,
    Andrew
    Well, I’ve done all I can think of to try and get this thing through emissions. I’ll be burning a couple of candles, praying to the gods of Chevy, throwing some salt over my shoulder and avoiding black cats until Monday morning when I try it again.......I hope it passes :dunno:
    I do have one question for you Edelbrock carb guy’s, as you face the vehicle, which side is the fuel adjustment screw on, Right or Left. I currently have both the Air/Fuel screws set at 1 ¼ turn out. I would like to try and “lean” it out as much as possible just before the test. I’m hoping by reducing the fuel at idle it will reduce the HC readings.
    I know the rings are shot in this motor so if it doesn’t pass this time, I’m going to pull it and do a basic rebuild. So the question I have concerns the 4 speed. If this were an Auto I would simply unbolt the torque converter and separate motor from tranny. Being a 4 speed can something similar be done? As I’ve mentioned in the past, I’ve never owned a rig with a stick in it so this will be a first for me.
    If anyone has a running 350 (that’s in decent shape) they want to get rid, please let me know, I may be interested in it.
    Thanks,
    Andrew
  2. mosesburb
    mosesburb For Rent Premium Member GMOTM Winner
    Apr 20, 2003
    2,172
    128
    Phoenix AZ
    You need to add fuel (richen) to reduce HC. You lean the mixture out to reduce CO.
  3. FWP
    FWP CRS
    Oct 11, 2000
    3,845
    3
    Prescott Valley, AZ
    Bummer. You know the rings are shot? How so? If you are getting oil in most of the cylinders, it will never pass emissions. Oil in the cylinders actually leans it out (less fuel to burn), thereby increasing HC, like Nick said. That's how I see it...
    Anyway, pull the tranny and t-case first. You're going to replace the clutch and do any needed maintenance to the tranny and tcase since you have it apart, right?
    Good luck!
  4. fatbob
    fatbob 1/2 ton status
    Jul 3, 2003
    420
    Phoenix, Az
    I passed the sniffer test but failed when they looked under the hood and noticed the hose from the valve cover to the air cleaner was not fully on.
    So I pushed it back on, went back though the line, and FAILED the sniffer test. Evidently the crankcase gases can make a big difference if you pass or fail, and since your rings are shot, it dont look good. But you could cheat. That is to plug up the hose real good and hook it back up so it looks functional. This might help get you by untill next year. :grin:
  5. teamhickman
    Aug 28, 2004
    226
    Buckeye, AZ.
    Well, I did both a wet and dry compression test during the tune up I did and saw dry pressure around 120 and wet pressures around 140. The lows were 85 dry and 110 wet. In addition, you can see it burning oil at low engine rpm. Once you get around 2500 rpm it tails off but as soon as you let off and cylinder pressure drops it starts to smoke again. It is very light, not like a mosquito sprayer but it is there.
    Everything I see indicates bad rings, it doesn’t do the start up "puff" of smoke that would indicate a valve issue. Since the initial emissions test passed the loaded HC test but failed the idle test I was hoping that I could “tune” it enough to get through…..wishful thinking!
    So if it fails on Monday, I’ll need to locate a decent machine shop and get started. I went by AZ speed and marine last week but they are very expensive.
    Thanks,
    Andrew
  6. fatbob
    Jul 3, 2003
    420
    Phoenix, Az
    The compression does not look bad, its the difference between cylinders. It should not be more than 10% between cylinders. I.E. dry 120psi to 85 psi indicates you may have something going on with the low cylinder. Ive got engines with worse reading though emissions, so dont give up yet. If you have it running too lean [Causing lean misfire] the fuel/air mixture may not ignite consistantly, and the unburnt fuel will cause you to fail. This can be cause by a vacuum leak.
    Here is a good trouble shooting site. Try it out. :grin:
    http://www.recarbco.com/technical/smog/smoginfo.html
  7. teamhickman
    Aug 28, 2004
    226
    Buckeye, AZ.
    it passed!!!!!!!!!!
    Thanks,
    Andrew
  8. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
    Cool :D
    When ya feel its ready to hit dirt hit me up . I will wheel when its warmer , although weekend nights and early mornings work too :grin:
  9. az-k5
    az-k5 1/2 ton status
    Oct 15, 2003
    2,774
    Phoenix AZ
    did somebody say night run?? :cool1:
  10. justhorsinaround
    justhorsinaround 3/4 ton status
    Sep 16, 2003
    6,798
    Northerish Phoenix, Az
    Night run? We think we finally have the oil leak at least staunched for now. Where are all those old driving lights I used to have? :o
  11. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
    Lights , who needs lights , we'll use Tj's blinding gigawatt of overheads and his disco ball on the ceiling :pimp:
