Emissions instal gone bad
Discussion in 'The Garage' started by 88trailblazer, Jul 4, 2005.
  1. 88trailblazer
    88trailblazer 1/2 ton status
    Apr 11, 2004
    425
    Miami, Florida
    Alright heres the situation. I just installed the AIR pump, lines, and manifolds on my '88. The previous owner had taken them all off, but the fumes were to strong. So i decided that I can live without the extra horsepower as long as I can open the back window without passing out.
    The 1st problem is that I can't find the wire that connects to the diverter valve. I'm not sure if he cut the wire because I don't know where the wire comes from. Any help or pics would be great.
    The 2nd problem is that now even though the engine idles better, the fumes are still strong. Even worse, and more importantly, the trannny doesn't seem to be shifting right. The tranny is shifting into 2nd gear to late and it doesn't shift into 3rd gear. I'm getting really frustrated with this and I'm even thinking of pulling everything back off so any help or advise would be great.
  2. BIG*RED
    BIG*RED 1/2 ton status
    Mar 14, 2003
    1,094
    as of right now, i can't say i even remeber seeing a wire going to my diverter valve..just vaccume line..
    and my exhaust fumes were really strong, until i put the catalitic convertor back on when i had to get it smogged..the fumes are not as bad now..
    anyways its about 1:45pm here on the west coast, and i just woke up..so give me a few, and i'll take the cell phone out and snap some pictures of my smog pump and diverter valve setup, then i'll post them up here for you.
    as for the tranny, gonna have to see who else posts up, because sounds like you have a auto, and i run a 465
  3. BIG*RED
    Mar 14, 2003
    1,094
    ok snapped a few pics..and yeah there is no wires going to the diverter valve
  4. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    Follow the vacuum line from the diverter valve back to its source. There may be a solenoid that controls vacuum to the valve.
  5. 88trailblazer
    Apr 11, 2004
    425
    Miami, Florida
    I guess they changed diverter vavles throughout the years because mine looks completely different. I did follow the vacuum line back and i found 1 wire but the connection is different and it doesn't reach the valve. Maybe I'm just missing a 1ft long adaptor or something. Oh yeah my tranny is a 700r4.
    Thanks for the pics sheoldeblaze.
  6. Mad-Dog
    Mad-Dog 1/2 ton status
    Mar 20, 2005
    548
    Ocklawaha,Fl
    Yea, that looks more like the heater comtrol valve to me....then again the pic is blurry.
    The diverter valve circuit is designed to open during part throttle or decellerating.
    The previous person probably snipped the wires at the harness very close to the solenoid and if you are lucky you can find them and reattach.
    Re-installing the emission control may not cure the problem if there is a exhaust leak elsewhere than the emission control circuit of pipes and hoses.
  7. BIG*RED
    Mar 14, 2003
    1,094
    no its the diverter valve, comes right up off the back of the smog pump, and the big hose you see is a air hose going to the air injectors, and the little vaccume line you see..well if you don't have that hooked up to the right vaccume it will back fire like a mother when you let off the gass
  8. Mad-Dog
    Mar 20, 2005
    548
    Ocklawaha,Fl
    Oops....my bad :blush:
    It's the top picture that screwed me up
    Man, It's been so long since i even looked at a Air injection Reactor pump (pretty fancy name for the POS).
    The extent of my emissions control system is a 10 degree vacuum advance canister.......:whistle:
  9. 88trailblazer
    Apr 11, 2004
    425
    Miami, Florida
    Well I found out the tranny problem was just a cable issue. But I still need help with the diverter vavle wire. :confused:
  10. dyeager535
    26,982
    191
    Maybe I'm way off base here, but I thought some of the TBI trucks didn't come with AIR, especially the first couple of years. If you had to install the manifolds, is there a chance that your truck isn't original with AIR?
    Not only that, but not all AIR setups were electronically controlled, at least not in ECM-less applications. (non-CCC, carbed)
  11. kram
    kram Registered Member
    May 29, 2005
    54
    Edison n.j.
    air pump
    my baby has both vac. and a two wire harness,maby six inches long from
    the egr harness pink and a black.single pipe in # 1 and # 2 exhaust port.
    i tried to insert pic but can't paste.[/IMG]
  12. sandawgk5
    sandawgk5 3/4 ton status
    Oct 28, 2003
    6,881
    Kitsap County PACNORWEST
    That is exactly how mine is and it looks like this.
    You can see the electrical connection on the end of the diverter and the vacuum line in the center of the diverter. Also you can see the single inlet to the passenger header. Drivers side is identical.
  13. Thunder
    Thunder 3/4 ton status
    Jul 20, 2000
    8,946
    Northeast Nevada
    I dont think putting all that stuff back on is going to help you with your fume problem. The A.I.R. system only operates when the engine is cold. It helps the cat convertor heat up and burns off the excess hydrocarbons in the rich fuel mixture needed when the engine is cold. After the engine warms up the divertor valves close and the air is vented to the atmosphere not thru the cat/exhaust..
  14. 88trailblazer
    Apr 11, 2004
    425
    Miami, Florida
    Thanks for the help and pics everyone.
    Yea, i know it won't solve the problem completely. But it wouldn't hurt,... just a couple horses.
