emissions Q
Discussion in 'The Garage' started by georgiared84, Jun 17, 2003.
  1. georgiared84
    georgiared84 1/2 ton status
    Sep 5, 2002
    487
    Austell, Georgia
    Took my first emissions test for this year and didn't pass. Here's the numbers
    25/25 test
    HC ppm- reading 153 allowed 148
    Everything else on the 25/25 test passed
    50/15 test
    HC ppm- reading 227 allowed 152
    CO% reading 1.93 allowed 1.36
    Everything else passed
    Here's some history on the truck:
    84 with 305 and quadrajet with about 150K miles. New cat last year. Truck runs pretty good except some smoke on startup (valve seals), and I get a fuel smell on the highway while decellerating after cruising for a while.It has new ignition wires and vac hoses, but I've never checked the dist. All the emis. crap is still there except for the AIR system. Passed last year with it disconnected so I took it off. The spark plugs foul up every couple thousand miles, so I usually change them out every other oil change but it's been a while since I did that so they probably look like crap. Haven't checked the egr or pcv since last year so they're probably not far from the plugs.
    Didn't do anything to the truck before testing. Warmed it up for about 20 min. and put the timing at about 4 btdc. Didn't want to buy anything until I tested since every cent counts towards exemption.
    Planning on new plugs, pcv, running a couple tanks of reg. with emissions pass stuff, knocking some crap out of the egr.
    Any other suggestions? Does that fuel smell on decell sound like fuel blowing by a fouled plug, or should I look at working on the carb? (I know unburned fuel will raise that HC #)
  2. Don
    Don 1/2 ton status
    May 30, 2002
    1,778
    Spokane Washington
    Tune it up, then before the test, drive the vehicle for 10 mile's or so,at highway speed, and then go to the test shop. Let it run while waiting, don't shut it off, You want it to be hot before the test.
  3. georgiared84
    Sep 5, 2002
    487
    Austell, Georgia
    Yeah, That's what I did this time. Guess I'll do that tune up and see.
  4. BlazerGuy
    BlazerGuy 3/4 ton status
    Apr 20, 2000
    9,206
    abcde
    Well, if your plugs are fouling up that fast the carb is probably runnning too rich. Leaning it out will, obviously, also lower the HC #. Make sure to change the filters too. /forums/images/graemlins/thinking.gif
  5. georgiared84
    Sep 5, 2002
    487
    Austell, Georgia
    How do you lean out a q-jet? All the filters are new.
  6. dyeager535
    26,979
    Forgot the "guaranteed pass" stuff (I've known people to fail with it, so it's not 100%) and just run a fair amount of alcohol.
