emissions removal
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by 86chevk5, Feb 6, 2003.
  1. 86chevk5
    86chevk5 Registered Member
    Dec 8, 2002
    10
    seattle
    I have a 86 k5 blazer and I want to remove all the emissions off the top of the engine. i want to put a new truck avenger and a edellbrock performer intake but im not sure what goes and what stays because i have an electric carb that runs off sensors on the engine and that thing is a piece of crap so i want to do away wit that but if anyone knows please help and if you have pics of you doing it that would help to. thanks /forums/images/graemlins/1zhelp.gif /forums/images/graemlins/k5.gif /forums/images/graemlins/usaflag.gif
  2. caryhenry
    caryhenry Registered Member
    Sep 28, 2002
    78
    Tallahassee, Fl
    On my 85 I removed everything except egr, vacuum advance, and the transmission vacuum switch on the firewall. Just make sure you cap and plug EVERYTHING
  3. dyeager535
    26,975
    You've planned how you will pass emissions without it? I know we don't have visual, but you won't make passing easier.
    How many electrical plugs on the carb? If 2, you'll have to replace the carb and distributor to get rid of ANY of the wiring in the engine bay.
    If there are two electrical plugs on the carb, I'm just outside of Seattle, and would be willing to take it off your hands. /forums/images/graemlins/smile.gif
  4. Can Can
    15,552
    136
    Cochrane, Alberta, Canada
    What are the emissions laws in your state? I'm assuming there aren't any, otherwise you wouldn't be wanting to remove your emmisions stuff.... /forums/images/graemlins/crazy.gif
    Another thing to remember is that *some* of your emission equipment is in place to help your truck warm up properly. If cold weather isn't an issue then go crazy and pull the following off:
    -AIR pump
    -All the plastic and steel air lines(the steel ones can be a real bitch to remove from the exhaust manifold, however)
    -All the AIR check valves(they kind of go together with the air lines)
    -EFE valve(you'll have to either extend your exhaust or buy a spacer)
    -I unplugged my EGR valve(some guys choose to keep theirs hooked up)
    -Disconnect your ESC computer(I believe this may require you to get ahold of a non-ESC distributor)
    -You can also remove your catalytic converter
    Make sure you leave the PCV valve and the evaporation canister in place and properly hooked up.
    That's about it from me, brother!!!
  5. dyeager535
    26,975
    Actually, in the county we are in, you have to pass a sniffer/treadmill test.
    You can pass it with a lot of emissions stuff missing, but you just make it harder on yourself.
  6. Grim-Reaper
    7,385
    Atlanta
    You problem is a bad sensor or a bad mix solonide in the carb. Personnaly I hate that model Quad. I would find a quad from about a 79-82 or so just before that mix soloniode. That will run the rest of the emmisions gear PROPERLY so it will pass but do away with the troublesome part. The only two things that are in any way on that truck that are sucking up power is the Air pump and the Cats. If you remove either you don't pass. The resto of the vacume lines and junk is EVAP or the controls for the Air pump and not hurting power at all.
    I personnaly stay as far away as I can from anything that Say's HOLLY including Quads rebuilt by Holly.
  7. jekbrown
    May 19, 2001
    45,029
    362
    Vancouver, WA, USA
    swap in a chunk of a pre-emmisions frame + vin... ala the "73 burb" prerunner build up they did in fourwheeler (think that was the right mag). next day, remove all the emissions stuff you dont want.
    j
  8. dyeager535
    26,975
    Can't do that easily...the '84 frame VIN is under the drivers seat, top of the frame rail. (stamped in, no tag) You'd have a hard time doing that with the body on.
    Besides, trucks here are registered based on looks. If it LOOKS like an '81+, it IS an '81+ (or '80 down, you know what I mean), regardless of VIN.
  9. 86chevk5
    Dec 8, 2002
    10
    seattle
    i have my truck registered in another conty wich doesnt require emissions so thats why i want it off and it makes it alot easier to work on and also i cant put the typ of carb i want on there unless that stuff is off
  10. dyeager535
    26,975
    Didn't answer how many electrical plugs the carb has...
    Unless you've already bought the carb, don't think you'll find many that agree with your carb choice anyways. Not that you asked of course.
    Is the motor otherwise stock or what? Sounds like it, and if so, an intake isn't going to impress you if that and a properly working carb are all you replace.
    And yes, I said properly working...if the Q-jet is messed up, then it would make a big difference swapping it, but its cheaper to rebuild them than replace.
    I'm not one to agree with yanking emissions off just to do it, as long as its working properly, so you won't find me very neutral on that subject. It's just that if you don't know what you are doing and go in there and rip stuff out, you could end up without transmission lockup, cruise, spark, and so on.
