Emissions Test
Discussion in 'The Lounge' started by Chevit, Aug 25, 2003.
  1. Chevit
    Chevit 1/2 ton status
    Dec 10, 2001
    1,492
    dnaltroP, nogerO
    Well I have been trying to get my wifes Mini van thru the emissions test with no luck. I have done the basic stuff (oil change, air filter, new cat, plugs, wires, DEQ in a can) ect...and still getting a high reading in the NOx gas reading, got any tricks or tips... /forums/images/graemlins/confused.gif
  2. ChevyCaGal
    ChevyCaGal 3/4 ton status
    Dec 16, 2000
    8,158
    Sacramento, CA USA
    91% rubbing alcohol.... I dumped in 4 bottles into my 12 gallon gas tank. It's the same stuff as that no pass no pay stuff, but you get far more for cheaper doing it that way. I always use it, just did to pass about 2 weeks ago. /forums/images/graemlins/thumb.gif
  3. chebywanna
    chebywanna 1/2 ton status
    Apr 20, 2003
    277
    streamwood, (chicago)
    or retarding the timing might work, thats what they did to mine and it passed.
  4. Chevit
    Dec 10, 2001
    1,492
    dnaltroP, nogerO
    My neighbor suggested that...
  5. Chevit
    Dec 10, 2001
    1,492
    dnaltroP, nogerO
    no distributer
  6. 88Silverado
    88Silverado 1/2 ton status
    Mar 13, 2003
    2,664
    Quartz Hill, So. Cal
    What kind of Minivan and Engine?
    BTW, the alcohol reduces the cylinder temp so NOx cant form.
  7. Chevit
    Dec 10, 2001
    1,492
    dnaltroP, nogerO
    1990 Plymouth Grande Voyager
    3.3 liter
  8. 88Silverado
    Mar 13, 2003
    2,664
    The NOx Failures are caused by high cylinder temps.
    NOx forms when the temp gets over something like 2500C.
    Advanced timing or lean condition can cause the temp to get too hot and form NOx.
    Usually the EGR bleeds cooler gas back into the cyl reducing temp and/or the Cat. Converter converts the NOx into something else. If the vehicle sat for awhile before running the test, the cat might not have been hot enough.
    So it could be timing and/or lean condition, but normally its the EGR system or bad Cat.
    Be careful about using Alcohol. It should be denatured if your going to use it but beware alcohol can break crud loose in the tank, and its pretty harsh on rubber products and engines if used in excessive amounts. Run the tank low, add some alcohol and try it again. If theres someplace that has Methonal fuel, you might try that also .
  9. Chevit
    Dec 10, 2001
    1,492
    dnaltroP, nogerO
    I made sure it was good and hot, I drove around twenty miles on the freeway.
    i do not even know were the EGR vlave is, the Chiltons book shows it mounted on the back or the throttle body but it ain't there. Went to the wrecking yard to see where it was located on another 3.3 but it was the same thing, just a bolt hole were it is suppose to be unless there is more than one spot that it can be located... /forums/images/graemlins/confused.gif
  10. 88Silverado
    Mar 13, 2003
    2,664
    Is it giving you a fault code in the computer?
    You might try to clear it then drive it around and see if it records any unusual paramaters.
    Usually when you fail test you can ask them what it wrong with it and they can usually tell you.
    If it was a test only location, this will probably mean you have to take it to a test & repair facility and pay them to tell you, then you can decide what to do.
    You can try the alcohol trick and hope it passes but if your going to fix it its either advanced timing, lean condition, converter or egr system. /forums/images/graemlins/tongue.gif
