emissions
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by dumbfounded, May 27, 2000.
  1. dumbfounded
    dumbfounded 1/2 ton status
    May 20, 2000
    176
    Castalia, NC
    Me again, I've got an important question. I've got a 78 cheyanne with AC, 350, 1/2ton, etc... I noticed in the spec page that in 77 or so they all started coming with catalytic converters. Is this 100% or did they have canadian models or any without. The sticker under the hood is gone and it doesn't have cats. Was wondering if it ever did. What other emissions did it have? air pump? egr? ETC? Mine has none of this and it doesn't look like it ever did. Manifolds dont have AIR connections ( maybe none did) Cats are easily put on but finding other stuff (if I need it) can be a little hastle....
    Blood, sweat, tears, and lots of money is what keeps my K5 alive.
  2. coopertwpk
    coopertwpk 1/2 ton status
    Mar 18, 2000
    478
    Spring Valley Lake Ca.
    most likely yours didnt it mostly was a california problem and until 86 most ran on leaded fuel with no Cat but they had air pumps
  3. dumbfounded
    May 20, 2000
    176
    Castalia, NC
    thanks. one more thing it doesn't have "unleaded fuel only" anywhere I can see so I'm hoping it didn't. My county will be phased into the "sniffer" test on emissions within the next couple of years....
  4. jarheadk5
    jarheadk5 1/2 ton status
    Mar 6, 2000
    4,389
    PA
    Since your county is going to be sniffing your tailpipe soon (boy, that phrase goes a few ways...), throwing on a cat or two won't hurt. Random Technologies makes hi-flow cats that have almost no restriction and weigh 75% less than stockers. I think it's randomtechnologies.com. Of course, if you investigate with the county and can find out what they say your truck should have for emiss. gear, you may not need to worry about anything!
    [​IMG] Semper Maintenance!
  5. DMK
    DMK 1/2 ton status
    Feb 20, 2000
    757
    CINCINNATI, OH
    Look in your glove box, the sticker in there will tell you if your truck came with heavy duty emissions or light duty.Heavy duty has no cat converter. It will also list if truck came with dual exhaust.
