end of project sale
Discussion in 'Engine | Tranny | T-case' started by big83chevy4x4, Mar 12, 2005.
  1. big83chevy4x4
    big83chevy4x4 3/4 ton status
    Mar 22, 2002
    6,587
    Sheridan, Michigan
    end of project sale...LOTS ADDED...PICS
    new 350 2 piece seal flex plate, has 250 miles on it $20
    tall 700r4-np208 adapter $40
    short 700r4-np208 adapter $40
    good mount for short adapter (9 months use) $10
    clocking ring and hardware (5/16" thick) (9 months use) $80
    non tilt auto column with 2 keys $40
    auto petal assembly $10
    AC pump serpentine bracket $30
    PS pump serpentine bracket $20
    700r4 dipsticks 1 lockingSOLD 1 standard Pending$5 each
    1 reverse rotation clutch fan $15
    alternator from 92 s10 blazer, worked when pulled $20 SOLD
    AC pump worked when pulled $20
    1 10 bolt 28 spline 6 lug axle shaft $10
    1 hydro clutch res. $1 Pending
    steering column boot $1
    clutch saftey switch $1
    26.5"x16" 1 core radiator came from 92 s10 blazer with 4.3, doesn't leak, looks new, with oil cooler sells new for $180 $75
    26.5"x18" 1 core radiator came from 86 cutlass cerria with 2.5 new, used 3 months sells new for $160, $75
    all prices OBO, buyer pays shipping, will ship radiators but perfer pickup.
  2. big83chevy4x4
    Mar 22, 2002
    6,587
    Sheridan, Michigan
  3. big83chevy4x4
    Mar 22, 2002
    6,587
    Sheridan, Michigan
    TTT again
  4. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
    Locking 700r4 dipstick , shipping to 85208 :D
  5. big83chevy4x4
    Mar 22, 2002
    6,587
    Sheridan, Michigan
  6. big83chevy4x4
    Mar 22, 2002
    6,587
    Sheridan, Michigan
    make me an offer on this stuff guys, i need it gone.
  7. smokkey1
    smokkey1 1/2 ton status
    Jan 7, 2004
    2,677
    Los Angeles, CA
    darn, I was hoping you were going to sell that crossmember you made when you clocked you x-case.
  8. big83chevy4x4
    Mar 22, 2002
    6,587
    Sheridan, Michigan
    ill sell that, i knew i was missing something. $15 or?
  9. smokkey1
    Jan 7, 2004
    2,677
    Los Angeles, CA
    sounds good. it should fit between the frame rails on an sub right?
  10. big83chevy4x4
    Mar 22, 2002
    6,587
    Sheridan, Michigan
    the frame rails are the same width so it better. it needs a paint job, and most of the welds arn't preaty (built it soon after i learned how to weld) but they have held under some preaty serious wheeling (ie: jumping) also the mount has been moved 1" to the left, it caused some header problems, but thats it.
  11. smokkey1
    Jan 7, 2004
    2,677
    Los Angeles, CA
    umm.... any problems with the mount being moved over an 1"???I asume it's to the passanger side...
  12. big83chevy4x4
    Mar 22, 2002
    6,587
    Sheridan, Michigan
    its to the driver side, i did it for exhaust clearance on the pass side. i ran it 9 months wit no problems other than the header moved over and touched the front driveshaft in certain situations, i can move it back the 1" if you want.
  13. smokkey1
    Jan 7, 2004
    2,677
    Los Angeles, CA
    nevermind, I'm going to pass on it. thanks for the offer to move it over :waytogo:
  14. big83chevy4x4
    Mar 22, 2002
    6,587
    Sheridan, Michigan
