  1. waterboy
    waterboy Registered Member
    Jun 8, 2000
    48
    what are the factory gears that come in a 10 bolt and can you run a 14 bolt sf in the rear with a 10 bolt front as long as they have the same gears
  2. chevy4x4
    chevy4x4 1/2 ton status
    Apr 27, 2000
    1,454
    Here ya go: 2.56, 2.73, 3.08, 3.42, 3.73, These are from the " Standard Catalog of 4x4's"
    You can run a 14 bolt in the rear and they don't have to have the same gears but they should.
    [​IMG]K5[​IMG]
  3. Rebel88
    Rebel88 1/2 ton status
    Sep 7, 2000
    1,855
    Richmond, VA
    I have an 88 with a 10 bolt that is packed with 3.73s and a gov-lok. Check your codes in your glove box and your dealer can tell you what you have.
    Have you driven OVER a Ford lately?
  4. laketex
    laketex 3/4 ton status
    6,220
    North Texas
    As long as your gear ratios are within .03 of each other, you'll be fine no matter what axles you run. Hope to help.
    Bryan
    [​IMG][​IMG]
    Durant, Ok
    '79 Blaze- 350/350/203, 14B w/detroit, D44, 4.11s, 4" susp, 36" TSL
